Importing Products
13 years 7 months ago #96241 by Tangram
Importing Products was created by Tangram
Im new to the software and i have a couple of questions about the importation of products.
I read the documentation and i didn't understand how to import the categories for the products. Do i need to insert them manually?
Another thing is what is the default folder for the images, if i put in the field image "front-black.jpg" where do i need to put that image in the system.
Thanks in advance.
13 years 7 months ago #96268 by nicolas
Replied by nicolas on topic Importing Products
You can insert them manually. If you don't have many of them it shouldn't be a problem.
Otherwise, they will be created automatically when the import system import your products and that it doesn't find the referenced categories in the database.
The default images folder is media/com_hikashop/upload
13 years 7 months ago #96378 by Tangram
Replied by Tangram on topic Importing Products
In the list that show me the things i can use it shows me "parent_category | categories_namekey | categories_image | categories_ordering | categories", is there a tutorial of what do they mean, for instance, if i have "electronics" and "computers", "computes" is a sub-category of "electronics"
how do i do that?
is the name the primary key for the category?
13 years 7 months ago #96441 by Xavier
Replied by Xavier on topic Importing Products
The documentation about imports is here: www.hikashop.com/fr/support/documentatio...shop-import.html#csv
To have many categories and sub-categories you need something like:
parent_category, categories
,electronics
electronics, computers
