Front page problem
13 years 6 months ago #98797 by Mitjag
Front page problem was created by Mitjag
Before I begin sorry for this but I can't see the right way to start and also somehow search function doesn't return me answer :(
I installed Hikashop on Joomla 2.5 (latest version) and created categories.
For test I created one product and now I have difficult to show it on fron page.
Here are printscreen:
What am I doing wrong?
Kind Regards
HIKASHOP NOOB :(((
13 years 6 months ago #98981 by Jerome
Replied by Jerome on topic Front page problem
The white popup with the content "3 Da..." is not logical.
You should see the content of the popup because there is a javascript which should copy the html content in the parent parent and close the popup.
So, I think you have a javascript error in your page.
Which version of HikaShop are you using ?
Would it be possible to have a backend access to your website in order to test it directly ? (you can send us such private information by private messae or via the contact form (indicating the url of this thread)).
Thanks,
The following user(s) said Thank You: Mitjag
13 years 6 months ago #99123 by Mitjag
Replied by Mitjag on topic Front page problem
Hi Jerome,
Yes indeed this white screen was strange also for me.
As for backend access. I just started to create this page for e-commerce and there is only:
- Joomla 2.5.9
- Hikashop (latest version 2.1.2
- only think additional installed is JCE Editor 2.3.2.4
I will send you login details to computer.
Thank you for your help.
Mitja
13 years 6 months ago #99199 by Xavier
Replied by Xavier on topic Front page problem
Can you enable the Joomla debug mode, and set the error reporting level to maximum, try to select again a category and see if an error message is displayed ?
13 years 6 months ago #99222 by Jerome
Thanks for the access.
We made a new package with a patch for this problem. You can re-download HikaShop and update your website.
13 years 6 months ago - 13 years 6 months ago #99323 by Mitjag
Thank you very much. I will test it and post results.
Edit: patch is working excelent. Thanks you again.
Last edit: 13 years 6 months ago by Mitjag.
