Several smaller configuration problems...
I am using Joomla Version 1.7.0 and HikaShop Essential 2.0.0 and have a few (hopefully simple) questions:
- absolutely basic, but I cannot find to solve this: How can I resize the product images? I searched through the forum and found the system-configuration-files settings which I changed; I emptied the thumbnail image folders, but the images are still resized to a smaller image size?!
- Is it possible (how?) to limit the number of products that can be ordered in the HikaShop Essential version?
- Is it possible (how?) to display both address fields as default and remove the checkbox (shipping address is different from billing address)? We want to offer music services for festivities which always take place at another address than the bill should be send to.
- How can the email that is sent to the client be adjusted? I added a custom field which I would like to display in the email as well
- My custom field, which is shown on the address website in the ordering process, should be visible at all the time. At the moment it is not - it is only displayed if the user clicks on the pencil to edit his/her address. How can I change this?
- Is there a possibility to show the total costs one last time right before the client clicks on "pay"?
Ups, this has been a lot of questions actually...sorry!
Thank you very much in advance for your help
First of all, why not updating the Joomla version to 2.5 and HikaShop to 2.1.2 ?
1. You can change the parameters in the Configuration > File tab. Change the sizes for the image thumbnail. The image managment has changed since 2.0.0
2. To limit click on the "product" menu and then in the toolbar you should see a "limit" button, it allow you to restrict the quantity of products by order.
3. For that you can edit the view "user / address" (require php knowledge) or you can do that via JavaScript.
4. To edit the mail you can go in the menu System > Emails (business edition) or edit in the folder "media/com_hikashop/mail" but the changes will be lost at each update.
5. I think that you need a custom field in the table "order" instead of "address" (business edition)
6. You can display the "cart" in the last step of the checkout.
Hope this will help you.
I updated to the most recent version of Hikashop and also to the business version as it has some features we needed!
Two questions stay open:
this only changes the thumbnail/preview pictures in the overview, but not the product "detail" view after you open a product page to read the description ... Where can I change this?1. You can change the parameters in the Configuration > File tab. Change the sizes for the image thumbnail. The image managment has changed since 2.0.0
2.) In the checkout step where I show the shipping methods there is a different header in the progress bar than on the page itself (see picture). Where can I change the second one, the title above the different shipping methods? In the language file I don't find this entry, so it must be somewhere else!
Thanks in advance!
Step 2-6 worked wonderful, thank you very much
1. Did you miss the "product page image width/height options of the Images section of the configuration ? That's where you can set the image width/height on the product details page.
2. Both are in the language file. Maybe you missed it too ?
2.) I looked at every single entry in the language file and did not find it. Emptied the cache and tried again. No chance...
Any other idea? Could there be used 2 language files?
2. There is only one language file. What language are you looking into ?
I added two screenshots to demonstrate the problem;
I don't want the pictures on the product overview page to be this big
but would like to make the product detail page picture bigger
The language file I am working with is /language/nl-NL/nl-NL.com_hikashop.ini
I can find any word there except for the word which is the title of the shipping page in the checkout process.
Thanks again for your help!
Thumbnail, is used for the listing, and product page for the image on the product page, you have to change these parameters.
Enable the option "thumbnail".
If it don't change, try to delete all the thumbnails images via ftp, they will be automatically created by HikaShop.
If it still doesn't work, it's maybe a template issue.
I deleted the pictures in this folder:
/httpdocs/media/com_hikashop/upload/thumbnail_300x225
and the settings are like this:
The thumbnail preview pictures look perfect now, but the product pictures are just the original pictures - the thumbnails are not created again?!
Also, where can I find the settings for the "Thank you page" after a succesful payment? I am redirected to the shop to the URL:
index.php?option=com_hikashop&ctrl=checkout&task=after_end&order_id=20
and would like to add some text here, but cannot find any options (google + board search did not help either).
Thanks for your help!
The return URL can be configured in your payment plugins.
And now hopefully the last ones!
- When clicking on the Terms and conditions during the checkout process, it opens a popup that shows the word "Articles" above the article - how can I remove this? (this word definitely can't be found in the Joomla content)
- The custom fields I created (category: order) are displayed below the address, which is great. I would like to replace them a bit as they stick together and are a bit too far left, how / where can I do this?
- When buying a product from the product overview, the user gets a popup (shop further / go to cart). This popup does not appear when the user has the product detail page opened and adds the product to the cart - can I active the popup here as well?
Thank you so much for your help!
1. Here is a message which explains what to do: www.hikashop.com/en/forum/4-how-to/18604...use-title.html#58469
2. You can use CSS to replace the fields. The exact CSS will depend on your template's CSS and what you exactly want to do. I guess that adding such CSS on your website should help:
.hikashop_checkout_additional_info td{
margin: 20px;
3. The popup should display everywhere. Maybe there is a javascript issue on your website, or maybe you had edited some view file before updating Hikashop from a previous version and that broke the popup display. Hard to say without looking at it.
