Script for adding many products.
13 years 6 months ago #100581
by kapis555
Script for adding many products. was created by kapis555
I'm creating shop with ~4000 products (spare parts), where essential things are product code, name, and quantity and Description changes only in different sub-categories.
I know only PHP basics. Is there any way to write a script which generates products for sub-categories?
Best Regards!
Best Regards!
- Thank you received: 1778
13 years 6 months ago #100588
by Mohamed Thelji
Replied by Mohamed Thelji on topic Script for adding many products.
Everything is possible with some development knowledge, but I think that the best solution would be to import your product through the CSV product import feature
13 years 6 months ago #100656
by kapis555
Replied by kapis555 on topic Script for adding many products.
Thanks, this forum is awesome
I will try it!
I will try it!
13 years 6 months ago #101415
by toneee
Hey there, I'm not sure if this will help, but I've created a Microsoft Excel spreadsheet with probably over 70 columns containing every field possible for a particular product. It comes complete with comments if you hover over many of the column headers and even a visual tutorial to demonstrate how to export the file as CSV and import into HikaShop 2.x+.
I know it works because I've used it to import a few hundred products myself. Please let me know if the spreadsheet and YouTube video is helpful; I just created it a hour ago because I hadn't seen anything like it. Thanks!
Replied by toneee on topic Script for adding many products.
kapis555 wrote: Thanks, this forum is awesome
I will try it!
13 years 6 months ago #101417
by Mohamed Thelji
Thanks toneee, I think that will help a lot of people with their CSV files
The following user(s) said Thank You: toneee
