Little layout problem
15 years 9 months ago #8098 by benkly
Little layout problem was created by benkly
could you please go to this page:
www.eiwomisa.de/website/shop-bausaetze.html
This is a "Categories listing" view. There you see the categorie titel "Bausätze" then under this the 2 child categories "LED-Leuchtmittel" and "LED-Steuerung". This is what I want to see!
BUT, then under this there comes again some things like a second time "Bausätze" with "LED-Leuchtmittel" under it and then "LEDs" with "Superflux LEDs" under it. How could I delete the last ones, I don't want them to be showed and I searched for hours now how to not show them.
Could you please help me!
Regards, Benny.
15 years 9 months ago #8101 by nicolas
Replied by nicolas on topic Re: Little layout problem
You need to go in the menu Display->Content menus. There, edit the menu with the id 161. Then, click on the select button of the option "associated modules" and set no for the module with the id 112. Then save the option and the menu's options.
15 years 9 months ago #8106 by benkly
Replied by benkly on topic Re: Little layout problem
Thanks, that was the trick to do ;-)
15 years 9 months ago #8120 by benkly
now a little other problem. When you go on my site again and click on the shop button on the upper side. If you now go around in the categories and show a product, how can I made that the accordion-menu on the left side synchonises?
Regards, Benny.
15 years 9 months ago #8127 by nicolas
That's not possible. Either you use menus like you did and you need to do the synchronization manually (or via a PHP/MySQL script that would have to be written) or you use a listing of categories hikashop content module, but you will be limited to one sub level of categories.
15 years 9 months ago #8166 by benkly
ok, that sounds bad. Will anything like a menutree be available in hikashop sometime? Is this planed?
Other problem, since I activated the hikashop on my site, I sometimes have 404 errors where the user anyhow clicks on a link with the ending "://0" in the product pages. But I cannot find how or where they click on such links.
Regards, Benny.
15 years 9 months ago #8167 by nicolas
Well, rather than having a menu tree, the solution will be to sync joomla menus with hikashop's categories. It's not planned as no one asked for it yet. We'll look at adding that in the future.
I couldn't see any link finishing with ://0 on your website. Could you point us to pages with such links ?
