- Thank you received: 2
order products by value
- elucidbusiness
13 years 6 months ago #102632
by elucidbusiness
order products by value was created by elucidbusiness
Web server crashed, so I have to setup everything again (yes, should have made a backup).
How can I by default show products in order of ascending value?
Cheers
Cheers
13 years 6 months ago #102654
by Jerome
Replied by Jerome on topic order products by value
Where do you want to change the order ?
In the front-end, back-end ? In a menu ? A module ?
- elucidbusiness
13 years 6 months ago #102661
by elucidbusiness
Replied by elucidbusiness on topic order products by value
Hi Jerome
I'm wanting to change in the front-end.
I had it on my previous installation - I think I may have modified some code - but can't remember what I did.
Cheers
Cheers
13 years 6 months ago #102665
by Xavier
Replied by Xavier on topic order products by value
Depending on which value ?
In the menu/module configuration, you can set the order via the option "Ordering direction" and the value on which you want to order via "Ordering field".
- elucidbusiness
13 years 6 months ago #103535
by elucidbusiness
Hi Xavier
I want to order my products within a category in ascending order using the field price_value
I cannot find an this option as the ordering field in the parameters.
13 years 6 months ago #103548
by Jerome
Ordering on the price is not possible and it has never been.
Between currencies, discounts, ACL, quantities... There are too variables to make a good and faster ordering.
But you can fill the "msrp price" and sort on this field.
- elucidbusiness
13 years 6 months ago #103592
by elucidbusiness
Well it is possible, because I had it working on my site for nearly a year.
Ok, let's take a different approach.
I can create a filter on price.
How can I automatically apply this filter? That is, by default the filter is in ascending order -- the user doesn't have to select ascending from the drop down list.
13 years 6 months ago #103603
Replied by nicolas on topic order products by value
There was never such option in HikaShop. Filters cannot be applied by default to a listing and the price_value cannot be used as an ordering value in a listing.
However, if you enter the retail price in your products, you can order them by retail price by selecting the product_msrp column in the "ordering column" option of your product listing menus/modules.
It is potentially possible to modify the product listing main MySQL with a hikashop plugin and add a left join to the hikashop_price table and order by the price_value if you want. The trigger to use is this one:
www.hikashop.com/en/support/documentatio...reProductListingLoad
That however requires to know programing so you might need the help of a developer.
The following user(s) said Thank You: elucidbusiness
- elucidbusiness
13 years 6 months ago #104106
by elucidbusiness
ok, so I've added a trigger to mysql to update the product_msrp field when the price_value field changes. This works well.
However, I now have common price showing on my website for the product view:
Common price: 49,70 € ($58.68)
Our price: $64.55 each
How do I hide the common price?
- elucidbusiness
13 years 6 months ago #104110
by elucidbusiness
Don't worry, fixed it.
