[SOLVED] "No Registration" problems
13 years 5 months ago - 13 years 5 months ago #106690 by roef
Ok can't get my head clear on this, not sure what's wrong.
The same e-mail adress can't buy twice when using "no registration".
Under HikaShop -> System -> Configuration -> Checkout,
I have set:
Login - No
Registration - No registration
Checkout workflow - untouched.
User registration in Joomla is set to No,
And both Joomla cache plugin & global cache is Off.
First buy works as it should (and only place the userinfo gets saved is in HikaShop -> Customers)
Next time the same e-mail trys to buy, it's stuck on the checkout page
with this in the error log:
PHP Notice: Trying to get property of non-object in
/administrator/components/com_hikashop/classes/user.php on line 544
/administrator/components/com_hikashop/classes/user.php on line 548
Not sure what I'm missing here?
Any help would be great!
Thanks!
Joomla 3.1 / HikaShop 2.1.3
Last edit: 13 years 5 months ago by roef. Reason: solved
13 years 5 months ago #106713 by nicolas
Replied by nicolas on topic "No Registration" problems
Two possibilities:
1. You have a bug which was already corrected on our end. Download again HikaShop and install it again and see if that helps.
2. You are using an email address which was already used to create a joomla user account before so it cannot be used for "no registration" checkout.
13 years 5 months ago #106715 by roef
Replied by roef on topic "No Registration" problems
Thanks for fast reply!
Cool will try download and reinstall.
13 years 5 months ago #106753 by roef
Yes a reinstall did the trick, never though of testing a simple thing like that :)
Thanks again!
