Not clickable products in brand listing
13 years 4 months ago #109039 by Lucy_N
Hello!
I have created the brand module, but when somebody clicks on any brand, the products of this brand are just displayed.
They are not clickable to open their full description. Is there any way to figure it out?
I searched the forum, but I didn't find something related to.
Thank you in advance.
13 years 4 months ago #109048 by Eliot
Hi there,
It's probably related to the options of your menu or of the related module.
Take a look at it to check if you didn't set the "Link to the product page" option to "no".
The following user(s) said Thank You: Lucy_N
13 years 4 months ago #109053 by Lucy_N
I can find the "Link to the product page" option neither in module nor in menu.
In the content module the "Link on main categories" option is yes.
Could you please tell me exactly where it may exist?
13 years 4 months ago #109055 by nicolas
We'll need a link to the page to tell you exactly. Otherwise, just edit all your products listing menus/modules via the menus Display->Content menus/modules of HikaShop and change the option for each one.
13 years 4 months ago #109139 by Lucy_N
Finally, I found that there is no "Link to the product page" option in content menu with type of content "brand". This option exists in "product" type of content.
The solution was to set as associated modules: "Associated products listing for category listing menu 113)" and not "Associated products listing for manufacturer listing menu 117).
So, the products displayed per brand are now clickable.
nicolas and eliot,
thank you a lot for your time!
