Import products that are within categories and sub
13 years 5 months ago #109300
by mank087
Import products that are within categories and sub was created by mank087
I currently use Ecwid as my main shopping cart and I am trying to import my products from there to Hikashop.
I have nearly 1000 products and each is within categories and sub categories. How can I import them and keep the ordering structure?
So for example my products are found like this:
Polymer Standards -> Organic Standards -> Nylon Standards -> Nylon Products.
When I try to import my csv file the Hika doesnt import the categories and sub-categories correctly.
13 years 5 months ago #109422
Replied by nicolas on topic Import products that are within categories and sub
You need to have your CSV respect the CSV structure of HikaShop and it will work. You can find the import documentation where that is explained here:
www.hikashop.com/en/support/documentatio...hikashop-import.html
The simplest though is to precreate your category structure via the interface. Then, simply have the categories column in your CSV with the category name of the products in it (so that would be the category "Nylon Products" in your example).
