- Thank you received: 2
Problem installing
13 years 4 months ago - 13 years 4 months ago #111375
by karlvann
Problem installing was created by karlvann
I had a problem and eventually deleted all of the mysql tables and tried installing again to sort it out, didn't work
When I install it from scratch, I get this
An error has occurred.
0 SQL=SELECT * FROM co466_hikashop_config
And It doesn't install
I'm using Latest joomla and latest hika business, Do I need to delete anything else before I install it?
Update, getting a new error now
1146 Table 'ausbeds1_lum.co466_hikashop_config' doesn't exist SQL=SELECT * FROM co466_hikashop_config
Last edit: 13 years 4 months ago by karlvann. Reason: new error
13 years 4 months ago #111381
Replied by nicolas on topic Problem installing
If you deleted all the HikaShop tables, you need to uninstall HikaShop via the joomla extension manager before installing it again.
Otherwise, Joomla will perform an update instead of a fresh install and it won't run the queries which create all the tables, leading to that mysql error because the configuration table is missing.
13 years 4 months ago #111382
by karlvann
Replied by karlvann on topic Problem installing
Hi, I have just fixed it in the last few minutes, and you are right.. I stupidly deleted the tables before uninstalling hikashop. It's all sorted now though.. thanks anyway!
