- Thank you received: 2
Product description on right @ product page
13 years 4 months ago #111472
by bootfair
Product description on right @ product page was created by bootfair
I am trying to find a way to get the product description aling to the right of the product image on the main product page after clicking on "choose options" button.
I have found a few old posts via search that descibes this but all of these posts mention display/views/ product show_default file to customise in order to move blocks around. The problem I am having is (we are using business version of hikashop) there isn't any show_default file tp edit under views. All I have is product show and this file does not have left-part, right-part, top or bottom bits.
Am I looking at the wrong posts to customise products page? Any help will be much appreciated. Thanks.
- Thank you received: 1778
13 years 4 months ago #111487
by Mohamed Thelji
Replied by Mohamed Thelji on topic Product description on right @ product page
The solution will be to :
- Go to "Hikashop->Display->Views"
- Edit the show_default file of the product view of your front-end template
- Move this code :
after this line :
Hope this will help you.
- Move this code :
<div id="hikashop_product_description_main" class="hikashop_product_description_main">
<?php
//DISPLAY the product description
echo JHTML::_('content.prepare',preg_replace('#<hr *id="system-readmore" */>#i','',$this->element->product_description));
</div>
<div id="hikashop_product_right_part" class="hikashop_product_right_part span6">
13 years 4 months ago #111495
by bootfair
Replied by bootfair on topic Product description on right @ product page
Thank you for your reply but like I have explained there is NO show_default file under views. There is a show (without _default added) and this file has no left, right, top or bottom parts to move blocks around. I am using the latest release of hikashop business pack.
13 years 4 months ago #111521
Replied by nicolas on topic Product description on right @ product page
There IS a show_default view file in the menu Display->Views.
It's not possible that you don't have it unless you deleted it, or you're not looking at the correct place.
13 years 4 months ago #111567
by bootfair
Many apologies. Yes there is one.
