Link to offsite purchase for certain products
13 years 4 months ago #112406
by dkudler
Link to offsite purchase for certain products was created by dkudler
At my site (stillpointdigital.com), I have
a shop that mostly sells ebooks
, which can be purchased and downloaded directly from my HikaShop.
I also, however, have a number of audiobooks that are sold exclusively through Audible.com.
What I am trying to do is figure out a way to change the "Add to Cart" button conditionally. If the product is in the category "Audiobook", say, I'd love to have the button read "Purchase at Audible" and link to the Audible page (which is already entered as the Brand URL for each product).
Is this possible without completely rewriting the code? If not, can you point me to where in the code I'd need to make changes?
13 years 4 months ago #112425
Replied by nicolas on topic Link to offsite purchase for certain products
You will have to edit the file "quantity" of the view "product" via the menu Display->Views and add your check at the beginning. Something like that:
<?php if(!empty($this->row->product_url)){
echo '<a href="'.$this->row->product_url.'">Add to cart</a>'; return;
13 years 4 months ago #112463
by dkudler
Replied by dkudler on topic Link to offsite purchase for certain products
Cool! Thanks!
I take it that the "else" would be an echo containing the button/link I'm looking to add, right?
13 years 4 months ago #112464
by dkudler
Whoops! Missed the ! at the beginning of the check.
I think I've got it. Thanks.
