A few questions
13 years 3 months ago #114478 by Soko?owski
Replied by Soko?owski on topic A few questions
If i change this line, then images work fine, but characteristic dont...
13 years 3 months ago #114727 by nicolas
Replied by nicolas on topic A few questions
Do you get a javascript error ? Can you look in your browser javascript log console ?
13 years 3 months ago #114814 by Soko?owski
I'm not sure if I'm looking in the right place. I'm using firebug and the "script". I dont see any errors. I tested with the changed code in characteristic.php and with default code.
13 years 3 months ago #115139 by nicolas
I checked your website but I couldn't see the change so I couldn't see if there was a problem and what kind of problem it could be.
Can you try like that please:
if(el && el2) el.innerHTML=el2.innerHTML.replace(\'rel="shadowbox[\',\'rel="shadowbox[copy_\');
13 years 3 months ago #115144 by Soko?owski
I added ur code.
Characteristics work, but now duplicate picture.
Now I left your code, so you can check it.
13 years 3 months ago #115172 by nicolas
Ok, that's great !
Let's try with that then:
if(el && el2) el.innerHTML=el2.innerHTML.replace(new Regex(\'rel="shadowbox\[\', g),\'rel="shadowbox[copy_\');
13 years 3 months ago #115177 by Soko?owski
Now characteristics dont work. And duplicate first picture.
13 years 3 months ago #115179 by nicolas
Try like that:
if(el && el2) el.innerHTML=el2.innerHTML.replace(new Regexp(\'rel="shadowbox\[\', 'g'),\'rel="shadowbox[copy_\');
13 years 3 months ago #115182 by Soko?owski
Now product page doesnt display
13 years 3 months ago #115234 by nicolas
I forgot escaping the quotes.
Try like that:\
if(el && el2) el.innerHTML=el2.innerHTML.replace(new Regexp(\'rel="shadowbox\[\', \'g\'),\'rel="shadowbox[copy_\');
13 years 3 months ago #115240 by Soko?owski
Characteristics dont work. Now duplicate only first picture.
13 years 3 months ago #115265 by nicolas
Try like that:
if(el && el2) el.innerHTML=el2.innerHTML.replace(new RegExp(\'rel="shadowbox\[\', \'g\'),\'rel="shadowbox[copy_\');
Apparently, the case is important.
13 years 3 months ago #115309 by Soko?owski
13 years 3 months ago #115319 by Jerome
Replied by Jerome on topic A few questions
What does "Characteristics dont work" mean ?
13 years 3 months ago #115335 by Soko?owski
If i change color of product,pictures dont change(i still see default pictures).
13 years 3 months ago #115381 by nicolas
The
character is causing some issues now.
do it like that and that will avoid the issue with it:
if(el && el2) el.innerHTML=el2.innerHTML.replace(new RegExp(\'rel="shadowbox.\', \'g\'),\'rel="shadowbox[copy_\');
The following user(s) said Thank You: Soko?owski
13 years 3 months ago #115403 by Soko?owski
Your solution is great! The characteristics of work, only duplicates the first image(is it possible to correct it?).
I'm very grateful for the help.
13 years 3 months ago #115434 by Soko?owski
hmm,
Firstly pictures dont duplicate, if i wait few minutes with open web browser and click on picture then pictures duplicate.
13 years 3 months ago #115531 by nicolas
It's not possible to change the duplication for the first image. It will require to rewrite the whole image display handling.
It's on the todo list, but it's a lot of work.
I couldn't get any other picture duplication on your page.
Time to create page: 0.109 seconds
