Problem with product page layout?
13 years 4 months ago #112504 by lithium2k
Hi there,
I am using a menu item to link to a category listing of products.
I have a menu for EN and FR languages.
The english page works well and shows all the products, using divs.
But for some reason the French menu shows the products, but it displays them in tables?
Even though i specifically set it to use Div layout.
Strange..Any ideas?
13 years 4 months ago #112525 by Jerome
We need more information about your configuration.
You can select (and override) the product layout in different places ; In menus, in modules, in categories, in product itself.
Can we have a screenshot of your french menu configuration ?
Thanks,
13 years 4 months ago #112569 by lithium2k
Here is my french menu item:
13 years 4 months ago #112570 by Jerome
Your menu is a category listing menu. You have to check the configuration of the attached product listing module.
You can click on the link in the zone "associated modules".
The configuration that we want to check is here (in the module).
13 years 4 months ago #112578 by lithium2k
I dont understand why the french and english are displaying differently.
I checked the configuration in the associated module and the layout type is also set to Div there.
But it is still displaying using tables as far as I can see.
13 years 4 months ago #112605 by Mohamed Thelji
Can you give me a link to your product page for testing purpose ? you're maybe checking the wrong content menu.
13 years 4 months ago - 13 years 4 months ago #112718 by lithium2k
The website is at
You can compare the English and Fr.
I can send admin if you need.
Last edit: 13 years 4 months ago by lithium2k.
13 years 4 months ago #113044 by Mohamed Thelji
Ok, I think that you should just configured your french content module (with the ID number 195)like your english content module (with the ID number 191). For example you can set the Type of Item Layout of your French listing to "Image and Title".
The following user(s) said Thank You: lithium2k
13 years 4 months ago #113286 by lithium2k
Thanks, fixed.
