help me. modul carousel not work...
- akmal_okey
13 years 4 months ago #113760
by akmal_okey
help me. modul carousel not work... was created by akmal_okey
please help me!. carousel not working .
this not slide automatic and not slide if i click button next or perivious in carousel button
this my link grosircibaduyut.p.ht/
and this pictures capture configuration .
13 years 4 months ago #113834
Replied by nicolas on topic help me. modul carousel not work...
This is because of the improper use of jquery from your template which creates a javascript error, preventing the carousel from being initialized properly on the page.
You will have to install the jquery easy plugin ( extensions.joomla.org/extensions/core-en...jquery-scripts/18327 ) and configure it to avoid the conflict and that should then work properly.
- akmal_okey
13 years 4 months ago #113851
by akmal_okey
Replied by akmal_okey on topic help me. modul carousel not work...
thanks nicolas.
but i not understand how to work this plugin . i beginer. and i can find the problem . sorry .
13 years 4 months ago #113879
by Eliot
Replied by Eliot on topic help me. modul carousel not work...
You may understand that we already have a lot of work on our own plugin so we can't really take the time to help you with this.
You should take a look at some tutorial or ask on the jquery easy plugin forum
13 years 4 months ago #113941
It's quite simple actually.
Simply install the plugin on your website, enable it and configure it to fix jquery on the frontend via the joomla plugins manager and voilà.
Also make sure that you turn off your joomla/template cache or you might not see the change.
