- Thank you received: 1
Hikashop module - Display Menu - Not working
13 years 3 months ago #113769
by iliep
Hikashop module - Display Menu - Not working was created by iliep
As far as I understanding, when you configure the Hikashop module and set something for the "Menu" value, that menu will be forced on pages that the module links to.
But that is not working
Not matter what I setting there, the module will just create links for the product page that are "menu-less" and so all the modules disappear.
Can you please explain how is this supposed to work?
13 years 3 months ago #113832
Replied by nicolas on topic Hikashop module - Display Menu - Not working
You understood the concept perfectly.
If the menu parameter is not taken into account, it's either that you're not editing the correct module, or that you're selecting a menu which has been archived, trashed or something similar.
13 years 3 months ago #113860
by iliep
Replied by iliep on topic Hikashop module - Display Menu - Not working
Thank you for your reply.
It seems that this works if and only if the menu you link to is a Hikashop menu type. All other types are simply ignored.
This is not clear from the help pages and I only found out by accident.
So the solution was to create a dummy-menu item of the type "Hikashop listing" and use that as a menu item to link to.
