changing products to default tax category
13 years 3 months ago #115597 by clarkvan21
I would like to know if there is a way to change all products at once to "default tax category" right now most of them are "none." There are about a thousand of them so one by one would be a real pain.
thanks!
Clark
13 years 3 months ago #115603 by nicolas
Sure. You can go to System>Mass action, create a new one and use the action "Update the values", select the column "product_tax_id" and enter the id of your tax category for it and then click on the "process" button at the top.
13 years 3 months ago #115614 by clarkvan21
I can't find this.
13 years 3 months ago #115629 by Xavier
The mass actions are available since HikaShop 2.2.0, thanks to download the latest version on our website and install it over the current install.
13 years 3 months ago #115645 by clarkvan21
I just updated but I can't find it. Could you give a more detailed description of where to look? Or maybe a screen shot?
Clark
13 years 3 months ago #115659 by Eliot
Are you sure you have the very last version (2.2.0)?
I so, it's in the same menu as Configuration, Zone and so on, at the bottom of the "System" menu of Hikashop.
13 years 3 months ago - 13 years 3 months ago #115756 by clarkvan21
It says that I have 2.2.0 under the "about" tab. This is what I get (see image.) Any thoughts?
Last edit: 13 years 3 months ago by clarkvan21.
13 years 3 months ago #115787 by Eliot
Could you try to reinstall? The mass action features is included in this built.
Maybe you should also try with another browser or after cleaning your cache.
