Retail price on category's products listing
13 years 3 months ago #115763 by JIK
My store is for wholesale orders only where resellers can login and buy products at the wholesale price. I have set a Retail Price on each product and a product price with access set to "registered" users. This works fine as unregistered visitors can see the retail price on the product page - with no add to cart. Logged in registered users see both the MSRP and the wholesale price, and can add products to the cart at the wholesale price. Perfect.
However, how can I get the Retail price to show on the category's product listing for unregistered and registered users (with no add to cart button)? At the moment it shows no price at all. I'm sure there is some code I can put into a view but can't determine what the code should be or which view.
Product page view
Category product listing view
13 years 3 months ago #115786 by Eliot
Hi there,
You just have to edit the file listing_price trough our views editor (Display>Views) and change these two lines:
if(isset($this->row->product_msrp) && @$this->row->product_msrp > 0.0 && JRequest::getCmd('layout') == 'show' && $this->params->get('from_module','') == ''){ ?>
and
To:
if(isset($this->row->product_msrp) && @$this->row->product_msrp > 0.0 && $this->params->get('from_module','') == ''){ ?>
and
13 years 3 months ago #116124 by JIK
Thanks Eliot, but that made no difference at all.
Still have the same issue - no price showing on the category listing.
13 years 3 months ago #116126 by nicolas
Edit your products listing module via the link of your menu's options screen that you can find via the menu Display->Content menus. There, you can turn on the display of the prices.
13 years 3 months ago #116136 by JIK
Hi Nicolas, I have already checked the box for display of prices in the listing module - but nothing shows:
13 years 3 months ago #116155 by Eliot
Your "Show taxed prices" option is set to inherit.
Try to change it ;)
13 years 3 months ago #116317 by JIK
Hi Eliot, I have tried setting it to "With tax", "No Tax" and "Display Both". It makes no change whatsoever. I still don't see the MSRP price on the category listing for the associated module. Any other ideas?
cheers!
13 years 3 months ago #116356 by Xavier
Are you sure that you have made the changes given by Eliot in the good view of the correct template via Configuration > Display > Views ?
13 years 3 months ago #116547 by JIK
Hi Xavier, yes, I think I have made the change as written by Eliot. I only have one template. The view I changed is product > listing_price.
Here is what my code looks like...
<?php /** * @package HikaShop for Joomla! * @version 2.2.0 * @author hikashop.com * @copyright (C) 2010-2013 HIKARI SOFTWARE. All rights reserved. * @license GNU/GPLv3 http://www.gnu.org/licenses/gpl-3.0.html */ defined('_JEXEC') or die('Restricted access'); ?><?php $class =''; if(!empty($this->row->prices) && count($this->row->prices)>1){ $class = ' hikashop_product_several_prices'; } if(isset($this->element->main->product_msrp) && !(@$this->row->product_msrp > 0.0) ) $this->row->product_msrp = $this->element->main->product_msrp; if(isset($this->row->product_msrp) && @$this->row->product_msrp > 0.0 && $this->params->get('from_module','') == ''){ ?> <span class="hikashop_product_msrp_price hikashop_product_price_full"> <?php echo JText::_('PRODUCT_MSRP_BEFORE'); ?> <span class="hikashop_product_price"> <?php $mainCurr = $this->currencyHelper->mainCurrency(); $app = JFactory::getApplication(); $currCurrency = $app->getUserState( HIKASHOP_COMPONENT.'.currency_id', $mainCurr ); $msrpCurrencied = $this->currencyHelper->convertUniquePrice($this->row->product_msrp,$mainCurr,$currCurrency); if($msrpCurrencied == $this->row->product_msrp) echo $this->currencyHelper->format($this->row->product_msrp,$mainCurr); else echo $this->currencyHelper->format($msrpCurrencied,$currCurrency).' ('.$this->currencyHelper->format($this->row->product_msrp,$mainCurr).')'; ?> </span> </span> <?php } ?> <span class="hikashop_product_price_full<?php echo $class; ?>"> <?php if(empty($this->row->prices)){ echo JText::_('FREE_PRICE'); }else{ $first=true; echo JText::_('PRICE_BEGINNING'); $i=0; if(isset($this->row->product_msrp) && @$this->row->product_msrp > 0.0 && $this->params->get('from_module','') == '') echo JText::_('PRODUCT_MSRP_AFTER').' '; if($this->params->get('price_with_tax',3)==3){ $config =& hikashop_config(); $this->params->set('price_with_tax',$config->get('price_with_tax')); } foreach($this->row->prices as $price){ if($first)$first=false; else echo JText::_('PRICE_SEPARATOR'); $start = JText::_('PRICE_BEGINNING_'.$i); if($start!='PRICE_BEGINNING_'.$i){ echo $start; } if(isset($price->price_min_quantity) && empty($this->cart_product_price) && $price->price_min_quantity>1){ echo '<span class="hikashop_product_price_with_min_qty hikashop_product_price_for_at_least_'.$price->price_min_quantity.'">'; } $classes = array('hikashop_product_price hikashop_product_price_'.$i); if(!empty($this->row->discount)){ $classes[]='hikashop_product_price_with_discount'; } if(!empty($this->row->discount)){ if($this->params->get('show_discount',3)==3){ $config =& hikashop_config(); $this->params->set('show_discount',$config->get('show_discount')); } if($this->params->get('show_discount')==1){ echo '<span class="hikashop_product_discount">'.JText::_('PRICE_DISCOUNT_START'); if(bccomp($this->row->discount->discount_flat_amount,0,5)!==0){ echo $this->currencyHelper->format(-1*$this->row->discount->discount_flat_amount,$price->price_currency_id); }elseif(bccomp($this->row->discount->discount_percent_amount,0,5)!==0){ echo -1*$this->row->discount->discount_percent_amount.'%'; } echo JText::_('PRICE_DISCOUNT_END').'</span>'; }elseif($this->params->get('show_discount')==2){ echo '<span class="hikashop_product_price_before_discount">'.JText::_('PRICE_DISCOUNT_START'); if($this->params->get('price_with_tax')){ echo $this->currencyHelper->format($price->price_value_without_discount_with_tax,$price->price_currency_id); } if($this->params->get('price_with_tax')==2){ echo JText::_('PRICE_BEFORE_TAX'); } if($this->params->get('price_with_tax')==2||!$this->params->get('price_with_tax')){ echo $this->currencyHelper->format($price->price_value_without_discount,$price->price_currency_id); } if($this->params->get('price_with_tax')==2){ echo JText::_('PRICE_AFTER_TAX'); } if($this->params->get('show_original_price','-1')=='-1'){ $config =& hikashop_config(); $this->params->set('show_original_price',$config->get('show_original_price')); } if($this->params->get('show_original_price') && !empty($price->price_orig_value_without_discount_with_tax)){ echo JText::_('PRICE_BEFORE_ORIG'); if($this->params->get('price_with_tax')){ echo $this->currencyHelper->format($price->price_orig_value_without_discount_with_tax,$price->price_orig_currency_id); } if($this->params->get('price_with_tax')==2){ echo JText::_('PRICE_BEFORE_TAX'); } if($this->params->get('price_with_tax')==2||!$this->params->get('price_with_tax') && !empty($price->price_orig_value_without_discount)){ echo $this->currencyHelper->format($price->price_orig_value_without_discount,$price->price_orig_currency_id); } if($this->params->get('price_with_tax')==2){ echo JText::_('PRICE_AFTER_TAX'); } echo JText::_('PRICE_AFTER_ORIG'); } echo JText::_('PRICE_DISCOUNT_END').'</span>'; }elseif($this->params->get('show_discount')==3){ } } echo '<span class="'.implode(' ',$classes).'">'; if($this->params->get('price_with_tax')){ echo $this->currencyHelper->format(@$price->price_value_with_tax,$price->price_currency_id); } if($this->params->get('price_with_tax')==2){ echo JText::_('PRICE_BEFORE_TAX'); } if($this->params->get('price_with_tax')==2||!$this->params->get('price_with_tax')){ echo $this->currencyHelper->format($price->price_value,$price->price_currency_id); } if($this->params->get('price_with_tax')==2){ echo JText::_('PRICE_AFTER_TAX'); } if($this->params->get('show_original_price','-1')=='-1'){ $config =& hikashop_config(); $this->params->set('show_original_price',$config->get('show_original_price')); } if($this->params->get('show_original_price') && !empty($price->price_orig_value)){ echo JText::_('PRICE_BEFORE_ORIG'); if($this->params->get('price_with_tax')){ echo $this->currencyHelper->format($price->price_orig_value_with_tax,$price->price_orig_currency_id); } if($this->params->get('price_with_tax')==2){ echo JText::_('PRICE_BEFORE_TAX'); } if($this->params->get('price_with_tax')==2||!$this->params->get('price_with_tax')){ echo $this->currencyHelper->format($price->price_orig_value,$price->price_orig_currency_id); } if($this->params->get('price_with_tax')==2){ echo JText::_('PRICE_AFTER_TAX'); } echo JText::_('PRICE_AFTER_ORIG'); } echo '</span> '; if(isset($price->price_min_quantity) && empty($this->cart_product_price) && $this->params->get('per_unit',1)){ if($price->price_min_quantity>1){ echo JText::sprintf('PER_UNIT_AT_LEAST_X_BOUGHT',$price->price_min_quantity); }else{ echo JText::_('PER_UNIT'); } } if($this->params->get('show_price_weight')){ if(!empty($this->element->product_id) && isset($this->row->product_weight) && bccomp($this->row->product_weight,0,3)){ echo JText::_('PRICE_SEPARATOR').'<span class="hikashop_product_price_per_weight_unit">'; if($this->params->get('price_with_tax')){ $weight_price = $price->price_value_with_tax / $this->row->product_weight; echo $this->currencyHelper->format($weight_price,$price->price_currency_id).' / '.JText::_($this->row->product_weight_unit); } if($this->params->get('price_with_tax')==2){ echo JText::_('PRICE_BEFORE_TAX'); } if($this->params->get('price_with_tax')==2||!$this->params->get('price_with_tax')){ $weight_price = $price->price_value / $this->row->product_weight; echo $this->currencyHelper->format($weight_price,$price->price_currency_id).' / '.JText::_($this->row->product_weight_unit); } if($this->params->get('price_with_tax')==2){ echo JText::_('PRICE_AFTER_TAX'); } echo '</span>'; } } if(isset($price->price_min_quantity) && empty($this->cart_product_price) && $price->price_min_quantity>1){ echo '</span>'; } $end = JText::_('PRICE_ENDING_'.$i); if($end!='PRICE_ENDING_'.$i){ echo $end; } $i++; } echo JText::_('PRICE_END'); } ?></span>
But I can only see the MSRP on the product pages, not on the product listings for the categories.
13 years 3 months ago #116622 by Xavier
Is the product listing a menu or a module ?
Because in the code there is a check on the modules, if it's a module we don't display the MSRP price.
You can check if you have a value in the msrp with (to use before the if condition):
echo $this->row->product_msrp;
To display the msrp even if it's in a module, you can remove the code:
13 years 3 months ago #116644 by JIK
Success! Xavier, that was it! I am using the Hikashop content module so as soon as I removed the module related code I got what I needed. Would be good to see this as a backend parameter in future versions as the ability to display the MSRP is extremely useful.
Thanks so much to you all for your help. You guys are the best. Very happy! :)
