Column problems
- fgalmere26
- Hi there!
13 years 3 months ago - 13 years 3 months ago #116458
by fgalmere26
I wish you a very good day.
Column problems was created by fgalmere26
I would like to have a column of 3 and 3 high, so I got 9 products on 1 page.
How to do that?
Thank you in advance. :huh:
Edit: As well in the category list..
How to do that?
Last edit: 13 years 3 months ago by fgalmere26.
- Thank you received: 1778
13 years 3 months ago - 13 years 3 months ago #116474
by Mohamed Thelji
Replied by Mohamed Thelji on topic Column problems
I think that you should :
- Go to your content menu configuration screen through "Hikashop->Display->Content menus->'YOUR CONTENT MENU'"
- Set the "Number of columns" option to 3
- Set the "Number of items" option to 9.
Hope this will help you a little.
Last edit: 13 years 3 months ago by Mohamed Thelji.
The following user(s) said Thank You: fgalmere26
- fgalmere26
- Hi there!
13 years 3 months ago #116480
by fgalmere26
Replied by fgalmere26 on topic Column problems
Thanks!
As far as I can see now, the categories are in the right place.
So I tried the same for my 'Products listing', but I still get the option Show (number).
What to do? :S
What to do? :S
13 years 3 months ago #116490
by Eliot
Replied by Eliot on topic Column problems
What do you mean by "I still get the option show"?
The method is exactly the same for the product listing.
The only difference could be that your listing is a content menu instead of a content module
- fgalmere26
- Hi there!
13 years 3 months ago #116501
by fgalmere26
Here I still get the option about how many items to show. When I open it in IE10 I only see the first 3, while I did the same as the categorylist.
Eliot wrote: What do you mean by "I still get the option show"?
The only difference could be that your listing is a content menu instead of a content module.
13 years 3 months ago #116651
Replied by nicolas on topic Column problems
Then it means that you didn't edit the options for the correct products listing.
Looking a the page www.fotografie-almere.nl/Joomla/index.ph...er-bedrag&Itemid=113 it's the module with the id 109 that you need to edit via the menu Display>Content modules and change the number of items option there.
