Problem, "strict standards" error Everywhere!
15 years 9 months ago #8600 by mercinater
Hello, I've installed hikashop for my joomla 1.6 and for some reason everywhere on my pages regarding to hikashop is coming back with floods of the following :
"Strict Standards: Only variables should be assigned by reference in C:\xampp\htdocs\joomla16\administrator\components\com_hikashop\views\menu\view.html.php on line 15
Strict Standards: Creating default object from empty value in C:\xampp\htdocs\joomla16\administrator\components\com_hikashop\views\menu\view.html.php on line 22
Strict Standards: Non-static method hikashop::completeLink() should not be called statically, assuming $this from incompatible context in C:\xampp\htdocs\joomla16\administrator\components\com_hikashop\views\menu\view.html.php on line 24
Strict Standards: Creating default object from empty value in C:\xampp\htdocs\joomla16\administrator\components\com_hikashop\views\menu\view.html.php on line 26
Strict Standards: Non-static method hikashop::completeLink() should not be called statically, assuming $this from incompatible context in C:\xampp\htdocs\joomla16\administrator\components\com_hikashop\views\menu\view.html.php on line 28
Strict Standards: Creating default object from empty value in C:\xampp\htdocs\joomla16\administrator\components\com_hikashop\views\menu\view.html.php on line 30
Strict Standards: Non-static method hikashop::completeLink() should not be called statically, assuming $this from incompatible context in C:\xampp\htdocs\joomla16\administrator\components\com_hikashop\views\menu\view.html.php on line 32
Strict Standards: Creating default object from empty value in C:\xampp\htdocs\joomla16\administrator\components\com_hikashop\views\menu\view.html.php on line 34
Strict Standards: Non-static method hikashop::completeLink() should not be called statically, assuming $this from incompatible context in C:\xampp\htdocs\joomla16\administrator\components\com_hikashop\views\menu\view.html.php on line 36
Strict Standards: Creating default object from empty value in C:\xampp\htdocs\joomla16\administrator\components\com_hikashop\views\menu\view.html.php on line 38
Strict Standards: Non-static method hikashop::completeLink() should not be called statically, assuming $this from incompatible context in C:\xampp\htdocs\joomla16\administrator\components\com_hikashop\views\menu\view.html.php on line 40
Strict Standards: Creating default object from empty value in C:\xampp\htdocs\joomla16\administrator\components\com_hikashop\views\menu\view.html.php on line 42
Strict Standards: Non-static method hikashop::completeLink() should not be called statically, assuming $this from incompatible context in C:\xampp\htdocs\joomla16\administrator\components\com_hikashop\views\menu\view.html.php on line 44
Strict Standards: Creating default object from empty value in C:\xampp\htdocs\joomla16\administrator\components\com_hikashop\views\menu\view.html.php on line 46
Strict Standards: Non-static method hikashop::completeLink() should not be called statically, assuming $this from incompatible context in C:\xampp\htdocs\joomla16\administrator\components\com_hikashop\views\menu\view.html.php on line 48
Strict Standards: Creating default object from empty value in C:\xampp\htdocs\joomla16\administrator\components\com_hikashop\views\menu\view.html.php on line 50
Strict Standards: Non-static method hikashop::completeLink() should not be called statically, assuming $this from incompatible context in C:\xampp\htdocs\joomla16\administrator\components\com_hikashop\views\menu\view.html.php on line 52
Strict Standards: Creating default object from empty value in C:\xampp\htdocs\joomla16\administrator\components\com_hikashop\views\menu\view.html.php on line 54
Strict Standards: Non-static method hikashop::completeLink() should not be called statically, assuming $this from incompatible context in C:\xampp\htdocs\joomla16\administrator\components\com_hikashop\views\menu\view.html.php on line 56
Strict Standards: Creating default object from empty value in C:\xampp\htdocs\joomla16\administrator\components\com_hikashop\views\menu\view.html.php on line 58
Strict Standards: Non-static method hikashop::completeLink() should not be called statically, assuming $this from incompatible context in C:\xampp\htdocs\joomla16\administrator\components\com_hikashop\views\menu\view.html.php on line 60
Because of this I am unable to even access the ability to use it in my upcoming webpage
15 years 9 months ago - 15 years 7 months ago #8612 by nicolas
Strict standards messages should not be displayed by PHP as they are disabled by default. Please edit your php.ini and change the error_reporting option to:
error_reporting = E_ALL & ~E_NOTICE
It's not related to joomla 1.6 but to the way your PHP 5 settings are.
Last edit: 15 years 7 months ago by nicolas.
15 years 9 months ago #8624 by joelin
thanks for replying,
but i've tried changing the error reporting settings and no matter what it still displays the errors everywhere
15 years 9 months ago - 15 years 9 months ago #8626 by mercinater
Even if it's removed [reminder that in my case it's still not] the module added to the page still do not even show through the added extensions
Last edit: 15 years 9 months ago by mercinater.
15 years 9 months ago - 15 years 9 months ago #8633 by nicolas
If you set that setting and restart your server, that should solve the display of those errors. This problem is not only in HikaShop but in almost all the extensions. You ca find dozens of posts on the joomla.org forum about it, and they all give the same solution I gave you:
forum.joomla.org/viewtopic.php?t=536127&f=429
@mercinater: I'm not sure I understand what you're saying ? The module doesn't show ? You're talking about the HikaShop content module ? Could you do some screenshots of the problem ? HikaShop works fine on joomla 1.6 and hundreds of people use it, so I would be surprised that it does for you...
Last edit: 15 years 9 months ago by nicolas.
15 years 9 months ago #8689 by mercinater
joe and I are at the same place both trying to get it to work but i've tried everything mentioned and even when it's verified by other people it's just not working for us for unknown reason
i have restarted the server, computer, tried on multiple browsers, changed code of the php.ini to error_reporting = E_ALL & ~E_NOTICE
but nothing is working
15 years 9 months ago #8691 by nicolas
If you're not able to do it via the php.ini, you can try to do it via an htaccess: forum.joomla.org/viewtopic.php?p=2002270
15 years 4 weeks ago #28375 by meiandmyself
hello, i m new in the world of joomla and just after istalling hikashop i get
Strict Standards: Only variables should be assigned by reference in... xampp\htdocs\capriccioitalian\plugins\system\hikashopuser\hikashopuser.php on line 66
Strict Standards: Only variables should be assigned by reference in... xampp\htdocs\capriccioitalian\plugins\system\hikashopuser\hikashopuser.php on line 16
i even cant open the menu components anymore
can please someone help me too?
thank you very much
15 years 4 weeks ago #28413 by nicolas
Please try to not post several messages about the same issue. Here is the following for other users:
www.hikashop.com/en/support/forum/2-gene...emhikashopuserh.html
14 years 8 months ago #41322 by kleeph
A quick way to fix this within windows is as follows:
1. Open your Joomla Config file
2. Locate: public $error_reporting = 'default';
3. Change that to: public $error_reporting = '6135';
Don't forget to change it back to default when you're ready to upload to final hosting server...
Hope this helps....
13 years 9 months ago #91467 by km2013
Not sure if you are still having problems, but you can cahnge the error reporting settings. Found a good youtube video.
YouTube
km.
The following user(s) said Thank You: tesla
