Problem with characteristics of product
13 years 3 months ago #119497 by cipionhabla
-- HikaShop version -- : 2.2.0
-- Joomla version -- : 3.1.5
-- PHP version -- : 5.3.27
-- Error-message(debug-mod must be tuned on) -- : Fatal error: Maximum execution time of 30 seconds exceeded and Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 71 bytes)
I have five characteristics created but when I try to add them to a product two different errors happened:
1. Fatal error: Maximum execution time of 30 seconds exceeded
2. Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 71 bytes)
The product doesn't work at backend or frontend. I need only one variant per product with different characteristics instead of many variants per product with different characteristics. And I can't use options because they are different products and either custom fields because they are for categories and not for a specific product.
Regards.
13 years 3 months ago #119518 by Mohamed Thelji
Can you tell me how many variants do you have for your product ?
13 years 3 months ago #119582 by cipionhabla
I attach two files for you, one with the product and his characteristics ( 8 ) and other with all the variants ( 205 )
13 years 3 months ago #119604 by nicolas
If you need only one variant then it's not characteristics that you need to use but custom fields of the table "item" that you can create via the menu System>Custom fields.
Characteristics are not made for what you want to do which it why you have that resources limitation issue coming from your server.
13 years 3 months ago - 13 years 3 months ago #119804 by cipionhabla
Ok, Thanks.
Last edit: 13 years 3 months ago by cipionhabla.
