adding products with different materials/costs
13 years 2 months ago - 13 years 2 months ago #121791 by tombreen
-- url of the page with the problem -- :site shop not yet live.
-- HikaShop version -- : 2.2.1
-- Joomla version -- : 2.5.8
I am struggling to implement a jewellery shop where each product is available in different materials (e.g 9 ct gold, 18 ct gold etc) each with different price. Thus far tried using characteristics with different price for each, but the price for 18 ct gold product is being added to the 9 ct gold option and not replacing it.
now sorted, think I had copied characteristics and options hence duplication- sorry...
Last edit: 13 years 2 months ago by tombreen. Reason: problem sorted.
13 years 2 months ago #121814 by Jerome
"Characteristics" makes an override of the product page. It changes it.
"Options" is an additional product link to the current product, it add his price to the linked product.
The following user(s) said Thank You: tombreen
13 years 2 months ago #122137 by tombreen
thanks- now getting 'out of stock' message when testing the cart- we have approx. 50 products, mainly wedding and engagement rings. Each ring is available in 4-6 different materials, each a different price, also in a range of sizes, all made to order. However, trying to implement this, am getting out of stock when trying to select any size other than 'unknown'. Does hikashop create a 'product' for 6 materials and 20 ring sizes, eg 120 products? If so, can we control the stock levels so that the out of stock message does not appear? thanks...
13 years 2 months ago #122151 by nicolas
Yes, if you're using characteristics, a variant is generated for each combination. You can click on the "manage variants" button of your product when you edit it to access the list of its variants and configure the quantity of each variant.
13 years 2 months ago #122159 by tombreen
thanks- is there any other way to structure this, as the size 'field' does not affect prices and it would be good to avoid having many hundreds of product variants, each of which would need to be managed? thanks!
13 years 2 months ago #122162 by nicolas
If you use an option instead of a characteristic, it won't be the case. Another solution is to create a custom field of the table "item" but that is only possible in the Business edition.
13 years 2 months ago #122176 by tombreen
thanks, trying to add an option for ring size, but going into the product and clicking add option just then takes me back to the prpduct itself with no way to create the option and the choices for that option...
13 years 2 months ago #122205 by Jerome
I don't understand your problem. I understand that you have a problem but I can clearly see what it is.
Can you provide a screenshot of something which will help us ?
13 years 2 months ago #122212 by tombreen
Hi, after a bit of digging, I have discovered that, in order to add no-cost options to a product, you first have to create another PRODUCT (e.g. ring size) and THEN add this as an option. Seems needlessly complicated! But working now, thanks for your help thus far...
13 years 2 months ago #122218 by tombreen
Still struggling with the set-up of product materials/prices- now OK, and choosing size of ring. Now getting 'The product is not available' error when testing the purchase, despite the product stock set up as unlimited. screen shot attached...
13 years 2 months ago #122242 by nicolas
Since you probably don't have any price in your options, you must turn on the option "display add to cart button for free products" or the system won't allow you to add free options to the cart.
13 years 2 months ago #122247 by tombreen
thanks, that has fixed this problem now...
13 years 2 months ago #123092 by tombreen
Hi, slowly moving forward with the jewellery shop. Current questions-
1. how to adjust the height of divs in category listing
temp shop page on this url- www.shirleyparisjewellery.co.uk/hikashop.html
2. how to not display option on category view and how to get thumbnail photo to centre in div-
on this url-
www.shirleyparisjewellery.co.uk/hikashop...ngs-online-shop.html
13 years 2 months ago #123101 by tombreen
correction- example engagement ring and ring size option shown on this page-
Ideally I do not want the ring size option to be seen until a ring has been selected, and then do not want an image associated with it...
13 years 2 months ago #123174 by Jerome
It is possible to implement such thing but it will require some PHP and Development skills.
You will need to edit some product views in order to change how the dropdown are displayed, adding some javascript to hide the dropdowns, add some javascript to trigger when a dropdown value is changed and show/hide other characteristics dropdowns depending to the selected values.
For the images, it is actually not possible. If a variant does not contains an image, the image of the main product is used.
But you can use the "image gallery" to select several times the same images for your variants (or do it thanks to the import).
13 years 2 months ago #123205 by tombreen
thanks for the info, a bit disappointing though to have to edit code for what is a fairly universal requirement...
13 years 1 week ago #132469 by tombreen
Hi again,
picking up the project again- getting confused re the config of characteristics. To summarise-
we are setting up a jewellery site, mainly expensive rings (wedding, engagement etc) and also earrings. Trying to create a 'sample' product for each type, then copy the product and change the prices, description etc. Created a characteristic called 'Choose ring Material' eg 9 ct gold £600, 18 ct white gold £1200, 18 ct yellow gold £1100 etc. And trying to reuse this characteristic on second copy of the product and editing the values. The second product is not picking up the char.and instead even when selecting a different material keeps coming back with a 'static' price. also is it possible to have say 6 material choices in general and for a specific product only have 4-5 of these? if so, how can this be done?
Test website on this url;- www.shirleyparisjewellery.co.uk/hikashop...t-ring-ref-2001.html this page works OK but this page does not-
www.shirleyparisjewellery.co.uk/hikashop...g-ring-ref-2002.html
thanks for any assistance!!
13 years 1 week ago #132540 by Xavier
You seems to be using an option and not variants for your products.
Thanks to post a screenshot of your product edition page.
If you use the options, you can change the price depending on the product, but with the variants you can.
You have to create a characteristic via the menu "Products > Characteristics" and add this characteristic to the product, and not on a product used as an option in your main products.
