disable right click on lightbox?
15 years 8 months ago #8699 by docconnolly
Hi Guys,
is there any way, to disable right clicks on the lightbox?i downloaded the "no right click module".they are disabled everywhere else.
thanks in advance-Mike
15 years 8 months ago #8700 by nicolas
I don't know. I've looked a bit at the code but I wouldn't be able to help you. You might want to ask the developer of the no right click module as hikashop just triggers the joomla standard popup lightbox and nothing more.
