RTL problem Iranian Currency
11 years 4 months ago #201951 by amirrezamahmoudi
-- Joomla version -- : 3.4.1
-- PHP version -- : 5.3.28
I have problem with IRR currecny.
The price doesnot show correctly.
for example instead of showing 49 000 IRR it shows IRR 00049
I would appreciate if you could help me in this regards,
11 years 4 months ago #201954 by nicolas
Edit your currency via the System>Currencies menu and remove the space in the "Groups separation" setting of your currency.
The following user(s) said Thank You: amirrezamahmoudi
11 years 4 months ago #202039 by amirrezamahmoudi
I really appreciate your kind supports. the problem has been solved.
Thanks a lot
Time to create page: 0.182 seconds
