Recaptcha 2 not working in domains using SSL
11 years 2 weeks ago #216902 by Najibeh
-- Joomla version -- : 3.4.3
-- Error-message(debug-mod must be tuned on) -- : Recaptcha 2 not working as soon as I issue a SSL certificate for site in the page registration
as issued in google support site there are needed some changes for server and other setting for the domains using SSL.
Could you please issue the new version of Recaptcha for https
thanks
Recaptcha 2 not working with domains using SSL
11 years 2 weeks ago #216906 by nicolas
Our ReCaptcha plugin works just fine on websites with SSL. We use it ourselves on our own website with a SSL certificate too.
So the problem is likely not in the code of the plugin.
11 years 2 weeks ago #216930 by Najibeh
in my website I do have two Plugin Captcha and Recaptcha both of them were working till i issued SSL.
The Recaptcha is giving error could not connect to google server
Could you please send me last Recaptcha file
11 years 2 weeks ago #216932 by Najibeh
its create the following error:
We couldn't contact the reCAPTCHA server to verify your answer. Please try again.
11 years 2 weeks ago #216939 by Jerome
The message you got have not link with the fact that you have a SSL in your website or not.
The error message you have indicates that the "file_get_content" on the URL " www.google.com/recaptcha/api/siteverify " is not working properly and it return no content at all.
11 years 2 weeks ago #216964 by Najibeh
So, Could you please guide me what can I do ?
11 years 2 weeks ago #217043 by nicolas
This indicates that your web server is configured in a way that it is not possible for the ReCaptcha plugin to contact the ReCaptcha servers. So you should seek the advice of your hosting company on how to authorize that access.
The following user(s) said Thank You: Najibeh
Time to create page: 0.217 seconds
