How do i move my products and categories?
- blade19941
15 years 8 months ago #8808
by blade19941
How do i move my products and categories? was created by blade19941
How do i move my products and categories from my hikashop site to another?
15 years 8 months ago #8816
Replied by nicolas on topic Re: How do i move my products and categories?
You can go in your phpmyadmin and export the tables starting with jos_hikashop_ on your old website. Then, install hikashop on your new website, remove all the tables starting jos_hikashop_ and finally import in your new website's phpmyadmin the SQL file generated by the export of the old website.
- blade19941
15 years 8 months ago #8817
by blade19941
Replied by blade19941 on topic Re: How do i move my products and categories?
I did that and this is how it came out.
www.soundrsa.com/
go to the products section
15 years 8 months ago #8820
I can't access your website. Do you see your products on your back end ? You would have to recreate your menus and modules if you didn't move the tables jos_menu and jos_modules
- blade19941
15 years 8 months ago #8822
by blade19941
try now, it was set on offline mode, sorry
15 years 8 months ago #8825
You have missing translation keys in your language file. You should update it and/or remove customization of views which might be different with the current version.
