Category module not showing in related products
10 years 3 months ago #246867 by haybug
-- Joomla version -- : 3.3.6
-- PHP version -- : 5.6.3
I would like to include the category list module and the breadcrumb when I click on any of the related products. How can I do this?
10 years 3 months ago #246883 by nicolas
In the "related products" module that you can edit via the Joomla modules manager, you'll find a "menu" setting where you can configure the target menu item when you click on a link of a related product displayed by the module.
So make sure that your other modules are assigned to the menu item selected in that option and they will display on the product page of the related products.
10 years 3 months ago #246986 by haybug
I cannot find the menu settings is it under the Hikashop Option?
10 years 3 months ago #246988 by nicolas
Edit your module via the Joomla modules manager and you'll find the settings of the module. There, under the "products options" tab, you'll see the "menu" setting.
