- Thank you received: 1
chart login problem
15 years 8 months ago #8893
by resif
chart login problem was created by resif
when i was guest adding a product chart and automatic coming register page and i registering but after i see empty page and i am goging to my mail and click activasion i am becoming login but i am seeing category list why not just chart or check out page? i want to see after register "look your mail message" and when was click activasion mail i want to see check out page my chart before (added a procuct)
15 years 8 months ago #8917
Replied by nicolas on topic Re: chart login problem
If you don't see the message after registration it's probably because of that:
www.hikashop.com/en/support/documentatio...tibility-issues.html
If your cart is lost when you're logged in, there is a high probability that the hikashop user synchronization plugin is unpublished. Could you check that it is published ?
15 years 8 months ago #8919
by resif
Replied by resif on topic Re: chart login problem
ok i added message before component at index.php. i am receving message after register
but still i after register and click activasion and i am losting in to cart(becoming empty)
i wantto see click after activason check-out page
which plug-in? and where?
15 years 8 months ago #8921
by resif
ok i saw and published it sorry. now i will try
15 years 8 months ago #8922
In the joomla plugin manager, you will find a plugin called "HikaShop user synchronization plugin"
15 years 8 months ago #8924
by resif
ok thak you but i have a little problem
i am receving now joomla default login mesasage " you can log-in...." but i am loged
how can i add for a message hika shop like this " activasion done and you loged you can check out)
15 years 8 months ago #8927
You can modify all the texts in HikaShop by editing your translation file in the config under the tab languages:
