How to fix this problem? Error Illegal mix of collisions
9 years 6 months ago #268989
by Tassanai
How to fix this problem? Error Illegal mix of collisions was created by Tassanai
-- Joomla version -- : Joomla! 3.7.0
-- PHP version -- : 3.5.8.2
-- Error-message(debug-mod must be tuned on) -- : Error Illegal mix of collisions (utf8_general_ci, IMPLICIT) and (utf8_unicode_ci, IMPLICIT) for operation '='
I checked the database in hikashop config.
9 years 6 months ago #269006
Replied by nicolas on topic How to fix this problem? Error Illegal mix of collisions
Edit your hikashop_user table or the users table of Joomla via your PHPMyAdmin and make sure that they use the same charset.
mediatemple.net/community/products/dv/20...er-set-and-collation
The following user(s) said Thank You: Tassanai
9 years 6 months ago #269058
by Tassanai
Replied by Tassanai on topic How to fix this problem? Error Illegal mix of collisions
I try to do as Hikashop told me already.
But there are also Error Messages, what do I do?
9 years 6 months ago #269059
by Tassanai
9 years 6 months ago #269064
In any case, note that this is not really a problem. The error only happens on a sycnhronization query which you don't normally have to use as HikaShop already synchornize the users between HikaShop and Joomla thanks to the HikaShop user synchronization plugin.
This query is only useful when the users are desynchronized because you made some changes like for example you migrated the tables of a HikaShop to another Joomla website and thus the users of HikaShop and Joomla are not synchronized.
Since it's probably not your case, you can simply ignore that message.
