- Thank you received: 2
Limit max q. per order with different Characterist
- emergentec
15 years 8 months ago #8980
by emergentec
Limit max q. per order with different Characterist was created by emergentec
Hi!
It is possible to limit the maximum quantity of one product per order. But if I use charecteristics for a product, I can add different variants of this product to the cart. Is it possible to limit it to only one variant of a product?
Best regards
Best regards
15 years 8 months ago #8985
Replied by nicolas on topic Re: Limit max q. per order with different Characterist
You can click on the "manage variants" button when you're on the edition page of your product in order to access the listing of variants of the product. For each variant, you can set a max quantity per order.
- emergentec
15 years 8 months ago #8988
by emergentec
Replied by emergentec on topic Re: Limit max q. per order with different Characterist
We use the variants to offer different long licenses of a product. Therefore it should be possible to order only ONE variant of a product. How is this possible?
15 years 8 months ago #8990
There is not such options.
- emergentec
15 years 8 months ago #9022
by emergentec
So that's only possible with a custom plugin, that checks the cart during checkout?
15 years 8 months ago #9039
Yes. You could just edit the cart file of the view checkout and add your products/variants checking code there.
