Export to CSV and Catagories Listing problem
- colingchong
15 years 8 months ago #9006
by colingchong
Export to CSV and Catagories Listing problem was created by colingchong
Is there a method of exporting the products in CSV that way I can keep all the new products consistent with existing products in a excel file and re-import them all in.
I am struggling to make a categories listing menu item that shows all my products from a specific category
ie. in one of my categories I have 119 products but when I click on that category it only shows 20, I have looked at the demo site and configured the category listing the same but cannot get it to show more than the 20.
Also, how do you change the background for the product image from the default gray in the catalog listing?
Many Thanks
Colin
Many Thanks
Colin
15 years 8 months ago #9028
Replied by nicolas on topic Re: Export to CSV and Catagories Listing problem
There is no export of products in CSV for now.
If you don't see all your products, that's probably because you have a number of item per page at 20 and that the random option is activated in the hikashop options of your module. You should go in the menu Display->Content modules and edit your module's options to change them to your needs.
There, you will also be able to change the background color.
- colingchong
15 years 8 months ago #9133
by colingchong
Replied by colingchong on topic Re: Export to CSV and Catagories Listing problem
Thanks, I think I've got the hang of that now
