Re: jcomments on products ?
16 years 3 weeks ago #932
by chaka
jcomments on products ? was created by chaka
ok i install jcomments
now where i selects the category product hikashop in configuration jcomments ?
i see all category joomla in my site , but i dont see the the category product hikashop.
sorry my english :blush:
16 years 3 weeks ago #935
Replied by nicolas on topic Re: jcomments on products ?
You can activate jcomments for the product page under the "display" tab in the configuration of HikaShop. That will activate comments on the product page.
16 years 3 weeks ago #937
by chaka
Replied by chaka on topic Re: jcomments on products ?
is active and nothing happens . when i choose any category ist works but i dont see the the category product hikashop .
and It says Successfully Saved, BUT if you go back in to that screen it still dont show the jComment
16 years 3 weeks ago - 16 years 3 weeks ago #938
by chaka
ok , i select several times , jcomments, jcomments,jcomments,jcomments, ... on until its work.
that is unusual.
thanks..
that is unusual.
thanks..
Last edit: 16 years 3 weeks ago by chaka.
16 years 1 week ago #1818
by panosm763
Replied by panosm763 on topic Re: jcomments on products ?
I have the same problem
16 years 1 week ago #1819
So it worked for you as well after selecting it several times ?
Which version are you using ? If it's older than 1.2.0 you should update as we fixed an issue on commenting system selection on the configuration page.
9 months 1 week ago #370441
by khashiz
Replied by khashiz on topic Re: jcomments on products ?
is that option still on display tab ?
i can't find it
i can't find it
9 months 1 week ago #370445
Yes, it's the option "Enable comments on products" :
www.hikashop.com/support/documentation/5...html#display_general
As explained in the documentation, the option only appear if you already have one of the supported extensions installed on the website.
9 months 1 week ago #370452
by khashiz
I have jComments installed, but there is no such option
9 months 1 week ago #370460
Then, please go through our contact form to provide a backend access, a FTP access and the URL of a product page so that we can look into it.
