How to remove product code from order and invoice?
15 years 8 months ago #9414 by mohairbears
Hi, can you advise how to remove the product code from sales/order in the product box, also remove from the invoice & shipping invoice.
thank you
15 years 8 months ago #9431 by nicolas
You need to go in the menu Display->Views and edit the files form and invoice of the view order and remove the code below from them :
.' '.$product->order_product_code
15 years 8 months ago #9432 by mohairbears
sorted thank you.
Another question though, Is is possible to send a duplicate email (summary of order) to another email address as well as the customer?
thanks in advance :cheer:
15 years 8 months ago #9433 by nicolas
Yes. You can edit the email via the menu System->Emails (business version only) and add the line:
$data->customer->user_email = array($data->customer->user_email,'my_other_email@gmail.com');
15 years 8 months ago #9790 by mohairbears
Hi, After many hours of reinstalling backups until I got a working one, this is what is causing the system error.
It will be me that is inserting it into the wrong place most likely as php is new to me.
I have put it in email: order creation notification
Can you advise exactly where to place this to get it to work correctly please.
thanks
15 years 8 months ago #9793 by mohairbears
Hi, this works for the below but it is still showing in the order when the customer accesses via the email link, it also going threw to PayPal, can you advise which file to amend to stop these please.
thanks
15 years 8 months ago #9833 by nicolas
You can add that code right after the first <?php tag ( only in the HTML version, not in the text version ) in the order creation notification email.
The product code in the order details of the front end is located in the file form of the view order of the front end. If you edited the one in the backend, it's normal that you don't see it on the front end. Also, please make sure that you did it for the good template.
For the product code on paypal, you will have to edit the file plugins/hikashoppayment/paypal.php and change the line
$vars["item_number_".$i]=$product->order_product_code;
to something like this:
$vars["item_number_".$i]=$product->order_product_id;
15 years 8 months ago #9861 by mohairbears
Hi, tried various placings for the email tag and it either place's the tag in text above the email or placing after the first <?php it crashes the system again?
<?php
* @version 1.4.7
* @author hikashop.com
* @copyright (C) 2010 HIKARI SOFTWARE. All rights reserved.
* @license www.hikashop.com/commercial_license.php
?> **placed here** wont work
<div style="background-color: #ffffff; font-family: Verdana, Arial, Helvetica, sans-serif;font-size:12px; color: #000000; width: 100%;">
<table style="margin: auto;font-family: Verdana, Arial, Helvetica, sans-serif;font-size:12px;" border="0" cellspacing="0" cellpadding="0">
<tbody>
<tr>
<td height="10">
</td>
</tr>
<tr>
<td>
<?php echo JText::sprintf('HI_CUSTOMER',@$data->customer->name);?>
**placed here crashes system**
<br/>
<br/>
<?php
$url = $data->order_number;
$config =& hikashop::config();
if($config->get('simplified_registration',0)!=2){
$url .= ' ( '.$data->order_url.' )';
echo JText::sprintf('ORDER_CREATION_SUCCESS_ON_WEBSITE_AT_DATE',$url,HIKASHOP_LIVE, hikashop::getDate(time(),'%d %B %Y'), hikashop::getDate(time(),'%H:%M'));?>
</td>
</tr>
<tr>
<td height="10">
</td>
</tr>
re the product code in the customer order screen: I appear not to have a order-form in the front end? only have two order in the front end and they are listing & show
changed in the back end ok and this does what you said it would earlier, but the code still shows in the customer order section??
The Paypal query works fine.
15 years 8 months ago #9863 by nicolas
You need to add that code right after the first <?php tag and not after the ?> tag.
ah right the front end one is called show and not form... sorry for that. You should edit the file show of the view order of the front end.
15 years 8 months ago #9864 by mohairbears
Sorry about this.. nearly there, the email now works but put's "array" in the Paypal email box??
<?php $data->customer->user_email = array($data->customer->user_email,'sales@mohairbearmakingsupplies.co.uk'); echo JText::sprintf('HI_CUSTOMER',@$data->customer->name);?>
The product code issue is solved.
thank you
15 years 8 months ago #9865 by nicolas
Could you edit the file plugins/hikashoppayment/paypal.php and add the line:
$user = hikashop::loadUser(true,true);
before the line:
$user = hikashop::loadUser(true);
15 years 7 months ago #11686 by mohairbears
Hi, just updated to 1.4.8 and I am now getting 'Item Number' on the PayPal email, I guess this is a change to 'Code'?
How do I stop this? delete $vars["item_number_".$i]=$product->order_product_id; in paypal.php?
thanks
15 years 7 months ago #11696 by nicolas
That modification was not applied to the plugin on our end. We only apply bug fixes. Customizations are not applied.
So yes, you need to reapply the same modification you did previously.
15 years 4 months ago #19015 by mohairbears
Hi, I have updated to 1.5.1 and I am now getting the product code showing again in Invoices and orders.
I have again gone through the below but there are new files so I think one of the new files must need changing.
Can you point me in the right direction please.
thanks
15 years 4 months ago #19030 by nicolas
The code is still the same for the product_code. If you did your modifications via the menu Display->Views, you didn't lost your modifications when updating HikaShop. But if you changed/deleted/updated your template, it might.
15 years 4 months ago #19127 by mohairbears
I did not change anything just upgraded, I have found the upgrade has made quite a few changes to the look of my site and no warnings or options to change it back.
Below is the PayPal email which has changed highlighted in red;
Cream (Tissavel) 13mm pile: Cream (Tissavel) 1/4
Item Number 2472
Honey 30mm pile **NEW**: 1/2
Item Number 2473
It appears to be pulling through both the product name & the product code where previously it would pull the product name of if that was blank then the procduct code.
The same thing is happening in the order & invoices except the item number is not showing (which is good)
There is also black margins around products which I have managed to get rid of by removing code from the CSS, there does not appear to be an option to change this without removing the code?
15 years 4 months ago #19134 by nicolas
The product name and the product code has always been sent to paypal with all the versions of HikaShop. Also, HikaShop does not have control over the emails sent by PayPal.
Once you customize once your CSS file, you won't get any CSS changes later on when you update. You got the CSS changes because you never customized your hikashop CSS up until now, so the system assumes that you want to keep it up to date.
The Product code can easily be removed on the orders on the front end with some CSS. For the invoice you need to edit the file invoice of the view checkout and remove it.
