Have products publish/unpublish autopmatically
15 years 8 months ago #9597 by momentis
Is there a way within HikaShop to set start and end publishing dates, similar to most Joomla content? I want to be able to populate products which appear only for periods of time (say, for a month) and then unpublish after that date.
15 years 8 months ago #9599 by nicolas
Yes. In HikaShop, when you edit a product you have the fields "sale start date" and sale end date" where you can define that.
15 years 8 months ago #9606 by momentis
I had found these fields, but they didn't seem to affect the front-end display. I selected one product and set it's "sale end date" to last Friday, then saved the product. However, the product still shows in the store.
15 years 8 months ago #9610 by nicolas
Yes, the item still shows but it should not be addable to the cart. Instead of the add to cart button, you should get a message like this: "This item will be sold starting on 09 Mars 2011"
15 years 8 months ago #9611 by momentis
Duh! Okay, I didn't even realize that! You know I'm going to ask this - is there a way to hide the products completely?
15 years 8 months ago #9613 by nicolas
There is no option to completely publish and unpublish products on fixed dates
15 years 8 months ago #9615 by momentis
15 years 7 months ago #10762 by FaberIptius
I have problems with the dates associated with a product (start and end sale dates).
Please, go to this page: www.allinonemicrosystems.it/index.php?op...2&category_pathway=0
I set a sale end date: 2011-03-11 10:29; but when you click o 'Aggiungi al carrello', no message is showing...
Thanks ;-)
15 years 7 months ago #10765 by nicolas
Isn't the problem a timezone problem ?
15 years 7 months ago #10767 by FaberIptius
I changed the date (pay attention to the year): 2000-02-11 10:29
The problem is still here :-(
15 years 7 months ago #10773 by nicolas
It seems that there is indeed a problem when you set the date for a product with characteristics.
Please try to edit the file quantity of the view product via the menu Display->Views and change the line:
if($this->row->product_sale_end && $this->row->product_sale_end<time()){
by:
if(($this->row->product_sale_end && $this->row->product_sale_end<time()) || (!empty($this->element->main)&&$this->element->main->product_sale_end && $this->element->main->product_sale_end<time())){
and the line:
}elseif($this->row->product_sale_start && $this->row->product_sale_start>time()){
by the line:
}elseif(($this->row->product_sale_start && $this->row->product_sale_start>time())||(!empty($this->element->main)&&$this->element->main->product_sale_start && $this->element->main->product_sale_start>time())){
and try again.
15 years 7 months ago #10778 by FaberIptius
It works!
Thank you so much :-)
