Arranging products in product module
15 years 8 months ago - 15 years 8 months ago #9602 by Dyamesz
Hi I just need to know how i can arrange the product according to how i want it or per product number. Currently it is randomly arranged and i cant seem to figure out how to arrange them based on the order i wanted. I have attached the image for your reference. Thanks
Last edit: 15 years 8 months ago by Dyamesz. Reason: add image
15 years 8 months ago #9620 by nicolas
In the listing of products, if the filter on the top right is set to "direct sub elements", you should be able to set the ordering of your products.
Then, in the hikashop options of your menu, please make sure that the random option is turned off and that you only display "direct sub elements".
