Inserted Products to articles - Alignment
14 years 2 weeks ago #75075 by dlarge
I have used the product button to insert products into a number of articles which is working very well though I have a slight issue with getting everything aligned as i want.
I have my page set as below, but I want the first two lines centered and the bottom line justified, but I can only get all the lines the same - either centered or justified. Is it possible to do what I want?
Dave
14 years 2 weeks ago #75080 by Mohamed Thelji
Hi Dave,
Can you show me what you really want to do with some screenshots ?
14 years 2 weeks ago #75114 by dlarge
Hi Mohamed,
I have attached two screen shots. The first one - is a joomla article with a product inserted, and as you can see the description below the product is centered. Ideally I would like the text fully justified or left aligned below the centered product.
I have attached how it looks on the product page and you can see the description text is left aligned which is what im after.
At the end of the day its no big deal but if its easy to do then would like to give it a go.
Dave
14 years 2 weeks ago #75232 by Mohamed Thelji
If you just want to justify or align your product description to the left you'll just have to add some CSS like :
.hikashop_inserted_product .hikashop_product_description { text-align: left; }
Or like :
.hikashop_inserted_product .hikashop_product_description { text-align: justify; }
Hope this will help you :).
The following user(s) said Thank You: dlarge
