- Thank you received: 1
Tax problem
12 years 1 week ago #179713
by Awards4u
Tax problem was created by Awards4u
www.awards4u.ca
-- Joomla version -- : 2.5.8
When I check out with this product www.awards4u.ca/medals/9683-3-custom-titan-medal-with-ribbon The tax comes out fine. However, when I check out with www.awards4u.ca/medals/9683-3-custom-titan-medal-with-ribbon There is no Tax? Even some other products are not calculating the tax. Any idea why?
Thanks,
Mohammed
Thanks,
Mohammed
12 years 1 week ago #179734
by Jerome
Replied by Jerome on topic Tax problem
I am sorry but your two links are exactly the sames.
12 years 1 week ago #179779
by Awards4u
Replied by Awards4u on topic Tax problem
Sorry, this is the other link
www.awards4u.ca/medals/7208-baseball-stardust-medal-with-ribbon
. This is the item that the tax doesn't work.
12 years 1 week ago #179789
Replied by nicolas on topic Tax problem
I would recommend to check the "tax category" field of the product edition page of that product and make sure that it correspond to the tax category that you selected in your tax rule (that you can see via the menu System>Taxes).
11 years 11 months ago #181546
by Awards4u
I have used Default tax category in the tax rules and in products I use Default tax category! The funny thing is that it works for most products but not all! Any other ideas to fix the problem.
11 years 11 months ago #181644
The problem comes from the fact that you had set a tax category to your variants in some way before.
As you had provided a backend access before, I've created a mass action (menu system>Mass actions) to force the tax category of all your variants to the default tax category and it works fine now.
Time to create page: 0.100 seconds
