The system counts in wrong way the product's tax
11 years 11 months ago - 11 years 11 months ago #181976 by 42bit
-- url of the page with the problem -- : www.rioteradeipensieri.org/
-- Joomla version -- : 3.3.6
-- PHP version -- : 5.3.29
-- Browser(s) name and version -- : Firefox 33.1
I've this issue.
The system counts in wrong way the product's tax. I.E. If I'm not logged in joomla the tax is right, but if i'm not logged in joomla the system counts double (in Italy tax is 22%, it counts 44%).
I've just tried to use default display view, but I think that the problem is before.
I didn't set any ACL in price setup.
I've attached screenshot to explain better the issue.
Can you help me.
Thank you
Antonio
Last edit: 11 years 11 months ago by 42bit.
11 years 11 months ago #181989 by Mohamed Thelji
Hello Antonio,
Can you show me how did you configured :
- Your product price
- Your taxes
Through some screenshots ?
11 years 11 months ago #182080 by 42bit
Yes of course,
In attachments.
11 years 11 months ago #182137 by Capperom
Hello Antonio, I also have the same problem, you have found the solution?
Romeo
Ciao Antonio, ho anch'io lo stesso problema, tu hai trovato la soluzione?
Grazie
Romeo
11 years 11 months ago #182141 by 42bit
Hi Romeo, no yet!
Support did not answer me yet!
11 years 11 months ago #182086 by Mohamed Thelji
You should unpublish the "Italia" tax.
The following user(s) said Thank You: 42bit
11 years 11 months ago #182191 by 42bit
Ok, It works well now!
Thanks for your support.
Antonio
