problem with TAXES
11 years 8 months ago - 11 years 8 months ago #194064
by nbstudio
problem with TAXES was created by nbstudio
-- Joomla version -- : 3.4
Hi (I removed the old text since I found the solution by myself)
Just a question
I want to add a text to tax exempt customers (they are included in a "0%" tax rule).
Is there a way to add this sentence to invoices?
Just a question
Last edit: 11 years 8 months ago by nbstudio.
11 years 8 months ago #194137
by nbstudio
Replied by nbstudio on topic problem with TAXES
I solved it by myself. I was too tired to notice.
Just a question
I want to add a text to tax exempt customers.
Just a question
11 years 8 months ago #194166
Replied by nicolas on topic problem with TAXES
You can edit invoices via the menu Display>Views by editing the file "invoice" of the view "order".
You could do something like that:
<?php if($taxes==0.0){
echo "you are tax exempt";
You can add that code at the end for example.
11 years 8 months ago - 11 years 8 months ago #194339
by nbstudio
11 years 8 months ago #194361
I don't see any easy way to do that as the tax amount in the order is not linked to the tax rule/tax note.
So you can't know which tax note to display. It would require hacking in the code of HikaShop to get that information when the tax rules are calculated and then store that information in the order when the order is created so that you can then display it in the invoice.
A simpler solution will be to have such code:
if(in_array($this->element->shipping_address->address_country,array('France','Germany', ...etc... ))){
echo "you are tax exempt in europe";
}else{
echo "you are tax exempt outside europe";
}else{
11 years 8 months ago #194821
by nbstudio
thanks. I made the modifications and after some hours of struggle, I succeeded.
