wishlist does not work
12 years 2 months ago #167795 by christina17
-- url of the page with the problem -- : www.chridiem.eu
-- Joomla version -- : 3.3.3
-- PHP version -- : 5.3.28
-- Browser(s) name and version -- : mozilla
I've got two problems and one question:
One with checkout (I have made a seperate topic for that).
One with the wishlist (listed here).
And one question regarding the categorylist. I will also make a seperate item for that.
I tried everything, but I can't get the wishlist working.
I thought of buying the german book. Maybe that could give some information.
But I am afraid it does not cover my problem.
I have tried to follow your tutorial "Using wishlist and carts". But i get confused between instructions for the administrator and instructions for the user. Anyway I had the wishlist in the sidebar and that did not work.
It said it had some products in the wishlist, but you could not view them. And the products still stayed in the cart.
Also I only see the add to cart option with a product and not the add to the wishlist option.
I changed the postion of the wishlist to cart. And that did niet work also.
I fewel I am going around in circles and nit getting at a solution.
Tineke
12 years 2 months ago #167797 by christina17
Replied by christina17 on topic wishlist does not work
I have solved the question about the categorie.
12 years 2 months ago #167864 by Xavier
Replied by Xavier on topic wishlist does not work
Can you give us a screenshot of you configuration regarding the wishlist in Configuration > Features > Wishlists ?
In the display part of the config do you have enabled the display of the wishlist button ?
12 years 2 months ago #167908 by christina17
Yes the display of the wishlist button is enabled.
For the configuration see att. 1
For a screenshot of the wishlist see att. 2
It says it has products in the wishlist, but as you can see there is nothing.
Tineke
12 years 2 months ago #167943 by Xavier
Sorry but the attachments are missing ;)
And on your website I am not able to see the wishlist module. Does it require to be logged in ? If it is thanks to give us a test account.
12 years 2 months ago #167988 by christina17
Hello Xavier,
Hereby a new attempt to sent the screenshots. I had a wrong format.
testaccount:
huubje
12huubje34
12 years 2 months ago #167990 by Xavier
The wishlist module issue seems to be a cache issue, if you have any cache enabled, thanks to disable it in the Joomla configuration, Joomla plugin, etc.
For the button, is the option "Display 'Add to wishlist' button" in Configuration > Display > Default parameters for "products" enabled ?
12 years 2 months ago #168110 by christina17
Hello Xavier
Cache in system was disabled. I don't see any cache items elsewere.
The display add to wishlist button was also enabled.
So I don't think this is the problem.
Tineke
12 years 2 months ago #168171 by Xavier
Do you have edited views ? Like "product / show_quantity" ?
If it is, thanks to backup your views, and remove the modifications by clicking on the dustbin in the views listing.
12 years 2 months ago #168293 by christina17
Hello Xavier,
If you mean all the items were there is a dustbin if you look at:
www.chridiem.eu/administrator/index.php?...m_hikashop&ctrl=view
then there are a lot of items with a dustbin, but not the one you mentioned.
As I believe most of this modifications are necessary to configure hikashop to your own needs, I don't think i should remove them.
Anyway here is a list and you can have a look if there is maybe someone who causes the conflict:
1 frontend it-trendyshop category carousel
1 frontend it-trendyshop category listing_list
1 frontend it-trendyshop checkout activate-page
1 frontend it-trendyshop checkout adress
1 frontend it-trendyshop checkout adress_view
1 frontend it-trendyshop checkout after_end
1 frontend it-trendyshop checkout cart
1 frontend it-trendyshop checkout cart_status
1 frontend it-trendyshop checkout cc_info
1 frontend it-trendyshop checkout confirm
1 frontend it-trendyshop checkout coupon
1 frontend it-trendyshop checkout cutom_fields
1 frontend it-trendyshop checkout end
1 frontend it-trendyshop checkout fields
1 frontend it-trendyshop checkout listing_price
1 frontend it-trendyshop checkout login
1 frontend it-trendyshop checkout login_form
1 frontend it-trendyshop checkout notice
1 frontend it-trendyshop checkout payment
1 frontend it-trendyshop checkout prontcart
1 frontend it-trendyshop checkout shipping
1 frontend it-trendyshop checkout status
1 frontend it-trendyshop checkout step
1 frontend it-trendyshop checkout terms
1 frontend it-trendyshop product cart
1 frontend it-trendyshop user cpanel
1 frontend it-trendyshop vote form
Tineke
12 years 2 months ago #168308 by Xavier
That should not cause the problem.
Thanks to give me a backend access to your website in order to see what's happening.
You can give it via pm with a link to that topic.
12 years 2 months ago #168467 by Xavier
There was indeed a mistake in the view "product / quantity" to show the wishlist button, this is an error from us.
I have corrected it on your end and it will be updated on our end for the next releases.
Regarding the wishlist module displaying items that should not be there I was not able to reproduce the issue, so I guess it was just a session issue, you can try on another browser and you hsould not be able to reproduce it.
12 years 2 months ago #168570 by christina17
Hello Xavier,
The add to wishlist button is now displayed. And it works.
Thank you for setting it right.
Tineke
  • graveltravel
  • graveltravel's Avatar
12 years 2 months ago #169348 by graveltravel
Replied by graveltravel on topic wishlist does not work
Hi Xavier, Tineke,
It seems that I have the same issues. The wishlist button appear, and when you press it the pop-up shows 'An error occured'. But the product is added to the wishlist.
I played with the cache but this doesn't make a difference.
Please advise.
Kind regards, Eric
12 years 2 months ago #169397 by christina17
Hello Graveltravel,
I don't think it is exact the same problem because I didn't get an error message.
In my case I could see the wishlist on the sidemenu and it said it had items. But it showed nothing when you clicked on it.
And setting items from wishlist to cart vice versa did not work.
If it is the same probblem, then you have to ask Xavier to fix it for you, because it was due to a bug in the system.
Tineke
12 years 2 months ago #169570 by Xavier
As Christina17 said, it don't seem to be the same problem.
Which version of HikaShop do you have ? And have you edited any views related on the wishlits / carts ?
  • graveltravel
12 years 2 months ago #169572 by graveltravel
Hi Christina, Tineke,
Yes, you are right ;-) I was a little to eager to post the problem I'm having at this thread. Latest version 2.3.2, installed on July 24th. Nope, I didn't make any changes to the sources of views. Of cause, I fiddled with the various options. For now I switched off the pop-up so the problem does not occur.
But I also had the problem with viewing the contents of the wishlist on one of the side-bars. So, I disabled this as well. That is why I posted the problem here. Because maybe there is/was a relation.
If you wish you may move this topic to another thread ;-)
Kind regards, Eric
Time to create page: 0.118 seconds
