'Add to cart' popup notice not working
13 years 10 months ago - 13 years 10 months ago #81377 by Abdyrai
I set "After a product is added to the cart" to "Stay and display a popup notice", but it doesn't work. I've added "<jdoc:include type="message" />" to template file. May you help me plz?
www.replicaclothingco.com/men-tees/item/122-men-s-starmen-tee
credentials removed by a moderator
Thanks,
Rai
Last edit: 13 years 10 months ago by Jerome.
13 years 10 months ago #81416 by Jerome
Could you try with the option "Use Ajax when possible" to yes ?
13 years 10 months ago #83317 by rebeccamantel
i also have this problem but when i click use ajax when possible to yes the popup shows error 404 page not found
13 years 10 months ago #83403 by Jerome
Could you provide a link to your store please ?
13 years 10 months ago #83513 by Mohamed Thelji
Are you using some SEF module ? if yes, can you turn it off and tell me if it works ?
13 years 10 months ago #83628 by rebeccamantel
no i don't use any sef module
13 years 10 months ago #83740 by rebeccamantel
Interesting when we are in this page www.acoustiquemedicaleschwartz.com/spark.../costume-accessories it is yes working as well as www.acoustiquemedicaleschwartz.com/spark...wn-hat-with-red-hair but in the page which shows only one article with the detail it doesnt work www.acoustiquemedicaleschwartz.com/spark...uct/24-foil-blowouts thank you
13 years 10 months ago - 13 years 10 months ago #83813 by Mohamed Thelji
I'm trying to solve the problem trough your back-end but when I'm loging in, I find a blank page but not your back-end.
A blank page does not help us to determine what could be the problem so if you get a blank page (an entire white screen without anything written on it), please make sure that your PHP configuration enables you to see errors and if not, edit your php.ini file and search for the string parameter display_errors.
This parameter should be turned On : display_errors = On.
If it's not the case, please edit your php.ini file, modify this line, save your file and then restart your server and try again to install HikaShop. You should not see a blank screen anymore and the error message will help us a lot to fix the problem.
If you can not see any error, please try to install HikaShop via FTP, it solves more than half of the installation issues.
Last edit: 13 years 10 months ago by Mohamed Thelji.
13 years 10 months ago #83814 by rebeccamantel
i dont understand how do you try to go in my back end
how do you log in do you need any of my details thank you
13 years 9 months ago #83899 by rebeccamantel
13 years 9 months ago #84239 by rebeccamantel
it is very strange what is happening i did turn on Use AJAX when possible
for add to cart buttons but then it only adds to one of the cart is it normal?
Also if i put the products as the home page than when i get to add to cart popup notice it doesn't work you can check it by clicking on home in www.acoustiquemedicaleschwartz.com/sparkle/ you wont be able to get the popup notice but if you click on products in the same page than you will yes be able to see the popup notice i dont really understand what it means??? thank you
13 years 9 months ago #84511 by Xavier
Can you try to enable the debug mode of Joomla and tell us what is the error returned ?
13 years 9 months ago #84514 by rebeccamantel
i enabled it but i am not sure what i am supposed to find there
__default
session.counter ⇒ 4
session.timer.start ⇒ 1357642311
session.timer.last ⇒ 1357642366
session.timer.now ⇒ 1357642370
session.client.browser ⇒ Mozilla/5.0 (Windows NT 6.1) AppleWebKit/537.11 (KHTML, like Gecko) Chrome/23.0.1271.97 Safari/537.11
registry ⇒ {"com_hikashop":{"ssl_redirect":0,"zone_id":"1375","vote":{"list_limit":"30"}}}
user
session.token ⇒ e880eb510e7ed8f155ff44582918bb79
Profile Information
Application 0.000 seconds (+0.000); 0.74 MB (+0.738) - afterLoad
Application 0.044 seconds (+0.044); 5.27 MB (+4.535) - afterInitialise
Application 0.077 seconds (+0.033); 9.15 MB (+3.874) - afterRoute
Application 0.166 seconds (+0.089); 16.53 MB (+7.381) - beforeRenderModule mod_hikashop (Related products)
Application 0.173 seconds (+0.008); 16.67 MB (+0.141) - afterRenderModule mod_hikashop (Related products)
Application 0.174 seconds (+0.001); 16.40 MB (-0.272) - afterDispatch
Application 0.179 seconds (+0.005); 16.53 MB (+0.135) - beforeRenderModule mod_menu (Footer menu)
Application 0.186 seconds (+0.007); 16.69 MB (+0.159) - afterRenderModule mod_menu (Footer menu)
Application 0.186 seconds (+0.000); 16.69 MB (-0.003) - beforeRenderModule mod_imgscrawler (Images Crawler)
Application 0.197 seconds (+0.011); 16.81 MB (+0.118) - afterRenderModule mod_imgscrawler (Images Crawler)
Application 0.197 seconds (+0.000); 16.78 MB (-0.028) - beforeRenderModule mod_hikashop_cart (MY CART)
Application 0.206 seconds (+0.008); 17.47 MB (+0.687) - afterRenderModule mod_hikashop_cart (MY CART)
Application 0.206 seconds (+0.000); 17.46 MB (-0.001) - beforeRenderModule mod_custom (free delivery on all orders over £25)
Application 0.208 seconds (+0.003); 17.47 MB (+0.007) - afterRenderModule mod_custom (free delivery on all orders over £25)
Application 0.208 seconds (+0.000); 17.47 MB (-0.002) - beforeRenderModule mod_menu (Store Catalog)
Application 0.216 seconds (+0.008); 17.50 MB (+0.030) - afterRenderModule mod_menu (Store Catalog)
Application 0.216 seconds (+0.000); 17.49 MB (-0.007) - beforeRenderModule mod_breadcrumbs (Breadcrumbs)
Application 0.220 seconds (+0.003); 17.53 MB (+0.033) - afterRenderModule mod_breadcrumbs (Breadcrumbs)
Application 0.220 seconds (+0.000); 17.54 MB (+0.013) - beforeRenderModule mod_AutsonSlideShow (Autson Slideshow)
Application 0.274 seconds (+0.054); 17.61 MB (+0.069) - afterRenderModule mod_AutsonSlideShow (Autson Slideshow)
Application 0.274 seconds (+0.000); 17.54 MB (-0.073) - beforeRenderModule mod_menu (Main Menu)
Application 0.283 seconds (+0.008); 17.54 MB (+0.009) - afterRenderModule mod_menu (Main Menu)
Application 0.283 seconds (+0.000); 17.54 MB (-0.006) - beforeRenderModule mod_search (Search)
Application 0.287 seconds (+0.004); 17.57 MB (+0.032) - afterRenderModule mod_search (Search)
Application 0.287 seconds (+0.000); 17.56 MB (-0.008) - beforeRenderModule mod_login (Login Form)
Application 0.294 seconds (+0.007); 17.66 MB (+0.101) - afterRenderModule mod_login (Login Form)
Application 0.336 seconds (+0.042); 17.82 MB (+0.151) - afterRender
i leave it on if you want you can check there because i am not sure what you are looking for there
i think the problem is that if i go through the default page to get to the product the url is not the same than if i go through a normal page like products for ex
through home page www.acoustiquemedicaleschwartz.com/spark...wn-hat-with-red-hair
through products www.acoustiquemedicaleschwartz.com/spark...wn-hat-with-red-hair
and in the second one it works
thank you so much
13 years 9 months ago #84515 by rebeccamantel
in the popup notice i get
Page not found : notice
Call stack
# Function Location
1 JSite->dispatch() JROOT/index.php:42
2 JComponentHelper::renderComponent() JROOT/includes/application.php:197
3 JComponentHelper::executeComponent() JROOT/libraries/joomla/application/component/helper.php:351
4 require_once() JROOT/libraries/joomla/application/component/helper.php:383
5 JError::raiseError() JROOT/components/com_hikashop/hikashop.php:58
6 JError::raise() JROOT/libraries/joomla/error/error.php:251
Session
13 years 9 months ago #84516 by rebeccamantel
and also
Call stack
# Function Location
1 JSite->dispatch() /home/acoustiq/public_html/sparkle/index.php:42
2 JComponentHelper::renderComponent() /home/acoustiq/public_html/sparkle/includes/application.php:197
3 JComponentHelper::executeComponent() /home/acoustiq/public_html/sparkle/libraries/joomla/application/component/helper.php:351
4 require_once() /home/acoustiq/public_html/sparkle/libraries/joomla/application/component/helper.php:383
5 JError::raiseError() /home/acoustiq/public_html/sparkle/components/com_hikashop/hikashop.php:58
6 JError::raise() /home/acoustiq/public_html/sparkle/libraries/joomla/error/error.php:251
13 years 9 months ago #84934 by Jerome
rebeccamantel wrote: in the popup notice i get
This error message is a little bit strange.
Do you have the file "components/com_hikashop/views/checkout/tmpl/notice.php" ?
13 years 9 months ago #86342 by Hariyani
I have same problem.. can you please help me to solve this problem.
I have already this file
13 years 9 months ago #86415 by Xavier
You have the same error displayed with your debug mode activated ?
13 years 9 months ago - 13 years 9 months ago #86479 by Hariyani
Let me explain visually.
Here i attached image. kindly check that image.
Last edit: 13 years 9 months ago by Hariyani.
Time to create page: 0.140 seconds
