problem with username in comment form
9 years 3 weeks ago - 9 years 3 weeks ago #281520
by olive
problem with username in comment form was created by olive
-- Joomla version -- : 3.7.2
-- PHP version -- : 5.6
In the comment form , if user comment for the product , It shows the username,
the problem is when you select "Simplified registration" in configuration.
In registration, it saves the email as username,
and in comment form it shows the email as username, but we don't like the others khnow the email of user,
In the "\vote\listing.php" file I changed the
<?php echo $elt->vote_pseudo; ?>
to
<?php echo $elt->name; ?>
It solves the problem for the user if they logged in before they comment
but if guest comment in the product it doesn't show anything,
I don't know how to slove this problem
to
Last edit: 9 years 3 weeks ago by olive.
- Thank you received: 1778
9 years 3 weeks ago #281537
by Mohamed Thelji
Replied by Mohamed Thelji on topic problem with username in comment form
In that case the solution will probably be to directly check if the comment was posted from a logged in user or not.
You'll be able to do it by checking if the variable $elt->vote_user_id is set or not :
if(isset($elt->vote_user_id))
9 years 3 weeks ago #281711
by olive
Replied by olive on topic problem with username in comment form
I used this code:
instead of :
but it doesn't solve the problem.
<td class="hika_comment_listing_name">
<?php if ($elt->vote_pseudo == '0') { ?>
<span class="hika_vote_listing_username"><?php echo $elt->username; ?> </span>
<?php } elseif(isset($elt->vote_user_id)) { ?>
<span class="hika_vote_listing_username" ><?php echo $elt->name; ?></span>
<?php } else{ ?>
<span class="hika_vote_listing_username" ><?php echo $elt->vote_pseudo; ?></span>
<?php } ?>
</td>
instead of :
<?php } else { ?>
<?php } ?>
</td>
9 years 3 weeks ago - 9 years 3 weeks ago #281740
by Philip
Replied by Philip on topic problem with username in comment form
There is something I don't get about this topic, see my screenshot to better understand my point of view :
=> First settings of Vote & Comment :
=> Results in my front end on my product page
Here, you see that everybody can vote & comment, and add a user name each time a comment is posted.
So, this way allow everybody to comment and if your customer is logged the name input isn't display.
Hope this will fit your needs.
Last edit: 9 years 3 weeks ago by Philip.
9 years 3 weeks ago - 9 years 3 weeks ago #281889
by olive
Hi again
No, It's not my mean. let to start from the begining:
In configuration:
then when user register it just enter email and password:
account information is created and "email" = "username"
then user loged in the site and comments in product page
and you see email of him,
It's the problem that we don't like to show email of user.
I used the solution that I explain in first post , but it makes another problem for guest.
In configuration:
9 years 3 weeks ago #281890
by Jerome
Replied by Jerome on topic problem with username in comment form
Now you can see to change your code to display the name and fallback on the "vote_pseudo" if that field is empty.
Yes, that is why the view display that "vote_pseudo" variable ; because it is where the information about the username is stored.I used the solution that I explain in first post , but it makes another problem for guest.
