- Thank you received: 19
Voting problem
6 years 3 months ago - 6 years 3 months ago #322508
by neo191987
Voting problem was created by neo191987
Hi, I have a strange problem voting on the product. The vote will not be reflected and if I delete the review, the vote will be reflected as a negative value. I also want to ask if there is an event after the vote is updated as with the filters: window.Oby.registerAjax('filters.updated',function(params){});
Last edit: 6 years 3 months ago by neo191987.
6 years 3 months ago #322543
Replied by nicolas on topic Voting problem
Hard to help you here without looking at the situation on your website, especially since the page is heavily customized.
Could you provide a screenshot of the settings of the votes in your HikaShop backend configuration page ?
And if you try the same with the default Joomla template (so without the customizations) does it work fine ?
6 years 3 months ago - 6 years 3 months ago #322549
by neo191987
Replied by neo191987 on topic Voting problem
Hi, I tested with a clean installation and installed demo of Hikashop, unfortunately the result is the same.
After the vote
After deleting the vote
Joomla 3.9.20 / HikaShop Business 4.3.0 [2007271529] / PHP 7.3.20 / XAMPP for Windows
After the vote
6 years 3 months ago #322633
Thanks for the feedback. I better understand what is going on. I didn't had the time to look into it today, but I'll work on that tomorrow and keep you posted on my findings.
The following user(s) said Thank You: neo191987
6 years 3 months ago #322696
I was able to reproduce the issue on my end and made a patch for it. It seems to work much better now.
Please download again the install package of the 4.3.0 on our website and install it on yours and it will add the patch.
It will of course be included in the next version of HikaShop.
