Display Products With effect
11 years 2 months ago #211288
by QureshiMo
Display Products With effect was created by QureshiMo
-- Joomla version -- : 3.4.3
-- PHP version -- : 5.5.12
Hello:
I would like to set up carousel like the last effect (One Product Disposition) one Hikashop has on the demo page.
Demo Page
I have set my carousel like it but have the following issues:
(1) Add to cart / wishlist appears only if hover on the image. I would like it to display always. Like your demo. I am using JSN Glass Pro and I think you demo is using the same template.
(2) The Add to Cart / Wishlist appears to be left aligned instead of in center.
This causes problems when I used other slide options (Like Div with 2 columns and 2 products per slide )
Thanks,
<<< Ali >>>
Hello:
Demo Page
Thanks,
<<< Ali >>>
11 years 2 months ago #211292
by Jerome
Replied by Jerome on topic Display Products With effect
See : www.hikashop.com/forum/product-category-...-of-add-to-cart.html
In our demo website, you can also access to the backend part of the website and see the modules settings directly.
