- Thank you received: 3
Problem with HikaShop Content Module on mobile devices
6 years 6 months ago #318956
by zetap
Problem with HikaShop Content Module on mobile devices was created by zetap
www.abierto.uy/
-- HikaShop version -- : 4.2.3
-- Joomla version -- : 3.9.18
-- PHP version -- : 7.3
-- Browser(s) name and version -- : chrome 81.0.4044.138 mobile - Android 7.1.1 SM-J250M Build/NMF26X
Hello
On the product page and seller page, I have configured HikaShop Content Modules, which show the seller's products, the most recently visited, etc. These modules have the carousel mode activated, configured to show 5 elements per transition, automatic transition every 5000 ms, activated so that the carousel movement controls are displayed.
When I visit the site from a mobile device, a cell phone for example, the module does not fit the screen of the device, only one product is shown, the first product of the 5 that would show on a computer (this is not so bad), but when it makes the transition, the next element it shows is the number 6, that is, it makes a transition of 5 elements and it is positioned in the 6th. The other problem that arises is that the controls are not visible on the screen of the cell phone and it is also not possible to move the elements of the carousel by touching the screen, as if doing a side scroll.
How can I reoilver this problem? thinking that the majority of site visitors and potential buyers use mobile devices to visit the site.
Greetings thank you !
Hello
6 years 6 months ago #318971
Replied by nicolas on topic Problem with HikaShop Content Module on mobile devices
You have the "carousel legacy" setting activated under the Advanced tab of the Hikashop configuration.
Because of that, you're using the old carousel system of HikaShop 1.x and 2.x which isn't responsive.
And thus, the carousel displays in 4 columns but on your mobile device, the width of the screen make it so that you only see the first column. And the pagination of the carousel doesn't display because it doesn't have enough width.
Turn off that setting in order to use the new carousel system and it should work better on mobile devices.
6 years 6 months ago #319070
by zetap
Replied by zetap on topic Problem with HikaShop Content Module on mobile devices
Hello, thanks for the answer
I followed your instructions and it worked perfectly, I did not know the function of that configuration, in my country there is a saying, "he who does not know, is like he who does not see"
Greetings, thank you very much!
