The carousel does not follow the setting 'Only with products'
6 years 4 days ago #326255 by neo191987
Hi, I created a module with content for a category, but when I activate the carousel, the setting 'Only with products' is not observed - all available categories are displayed.
6 years 3 days ago #326281 by nicolas
You're totally correct.
That setting is currently ignored in carousel mode.
Add the code:
$rows = array(); if($this->params->get('only_if_products','-1')=='-1'){ $config = hikashop_config(); $defaultParams = $config->get('default_params'); $this->params->set('only_if_products',@$defaultParams['only_if_products']); } $only_if_products = $this->params->get('only_if_products',0); foreach($this->rows as $row) { if($only_if_products && $row->number_of_products < 1) continue; $rows[] = $row; } $this->rows = $rows;
at the beginning of the view file category / carousel.php via the menu Display>Views and it should work properly.
We'll add that patch on our end for the next version.
The following user(s) said Thank You: neo191987
