- Thank you received: 4
Products Not Appearing/ Hikashop Hidden Menu Created
- daedalusteks
3 years 5 months ago #352029
by daedalusteks
Products Not Appearing/ Hikashop Hidden Menu Created was created by daedalusteks
-- HikaShop version -- : 4.7.2
-- Joomla version -- : 4.31
-- PHP version -- : 8.2
I created a carousel for categories in hikashop. When I published it, the categories show. Once you click a category to show products in category, it takes you to a blank page. I noticed the url took me to a hidden hiksashop menu instead of the product page. Not sure why it is doing that or how to resolve it. I looked at the hidden menu, but there is only 1, so i cant set it to a specific product page due to the multiple categories in the slider.
3 years 5 months ago #352030
Replied by nicolas on topic Products Not Appearing/ Hikashop Hidden Menu Created
In your categories carousel module, you have a "menu" setting under the "HikaShop options" tab. There you need to select the menu item you want the module to use when generating the links. So make sure you're using the menu item you configured to list your products and you should get the same products / links.
