Product waitlist notification is not running
10 years 6 months ago #241187 by bdladmin
-- url of the page with the problem -- : www.bijouxdelou.com
-- Joomla version -- : 3.5.1
-- Error-message(debug-mod must be tuned on) -- : Product waitlist notification is not running.
The product notification plugin is enabled.
The cron job is running.
I see the currency/rates update and out of stock notification are running but the product notification is not running (when the report is viewed).
Product notification was running fine until May 8, 2016. After May 8, my subscription expired and I renewed on May 11. It looks like product notification has not been running since May 11, 2016.
I searched the forums and came upon this thread:
hikashop.com/forum/customers/869466-waitlist-details.html
Did the same thing happen to me since I allowed my subscription to pass for around 3 days?
My cron URL is:
www.bijouxdelou.com/index.php?option=com_hikashop&ctrl=cron
Please advise.
10 years 6 months ago #241217 by bdladmin
I do not know what you did but waitlist notify now works. It ran 2 hours ago (an hour after this ticket was raised) and just ran a few minutes ago (intervals of 2 hours which is the normal interval for waitlist notify). Will continue to monitor the script.
10 years 6 months ago #241203 by nicolas
I've checked on our end and the cron task is running fine:
Connection accepted to the host : www.bijouxdelou.com : 80
at 26 May 16 14:02:09
=> Result of the trigger at 26 May 16 14:02:30
HTTP/1.1 200 OK
Date: Thu, 26 May 2016 11:44:13 GMT
Server: Apache
X-Powered-By: PHP/5.3.24
Set-Cookie: d996b725e17f3c61a2eacdffd9494a14=a83aed57d4f8660870d2768e180fad79; path=/; HttpOnly
Vary: Accept-Encoding
Connection: close
Transfer-Encoding: chunked
Content-Type: text/html
a1
<div class="alert alert-info alert-block"><button type="button" class="close" data-dismiss="alert">�</button><p>HikaShop Triggered at 2016-05-26 19:44</p></div>
Note that the waitlist plugin will send emails only if you have customers who entered their emails to be notified and that you put back some stock for the products. I don't see another reason.
