Mass-batch move products in warehouse
10 years 2 months ago - 10 years 2 months ago #249776 by mojweb
-- Joomla version -- : 3.6.2
Is there a simple way to move all products to warehouse?
I have some 400 products with no warehouse selected. I created 2 warehouses and want to move all products to one of them.
Thank you
Last edit: 10 years 2 months ago by mojweb. Reason: solved
10 years 2 months ago - 10 years 2 months ago #249805 by Mohamed Thelji
The solution will be to use a "Mass Action" via "Hikashop->System->Mass Actions", note that you'll also have to add a Filter to properly select which products will have which warehouse.
Last edit: 10 years 2 months ago by Mohamed Thelji.
The following user(s) said Thank You: mojweb
