- Thank you received: 1
Problem with filter slider
- wideservices
12 years 6 months ago #154058
by wideservices
Problem with filter slider was created by wideservices
moodleshop.wideservices.gr/en/
-- HikaShop version -- : HikaShop Business: 2.3.0
-- Joomla version -- : 3.2.3
-- PHP version -- : 5.4.22
-- Browser(s) name and version -- : all - latest version
I am using hikashop with rn shop template.
At my frontpage i use the slideshow ck and i have a hikashop module with filters. When i use a filter slider (eg. price 1-100) i get NaN where the numbers should appear. This happens only when slideshow ck is enabled and the strange thing is that i dont get any js errors! Can you look at it?
Thank you in advance
- wideservices
12 years 6 months ago #154085
by wideservices
Replied by wideservices on topic Problem with filter slider
Actually i found the solution . Had to disable jquery mobile from slideshow ck advanced settings. So problem solved
12 years 6 months ago #154117
by Xavier
Replied by Xavier on topic Problem with filter slider
Glad to see that your problem is solved and thanks for having shared your solution.
